Question about Cell Phones
My shuttle is doing the same thing
Powering on and off repeatedly ... the only way I got it to stop was remove the battery
but once I put the battery back in it does the same **** ... cant find any solutions online either
called the company and they said just send it back which has me loseing all my minutes and texts of course
  • 389 Answers
Unfortunately the phone is experiencing software issues, it needs to have a reflash, it means that it needs a software replacement, the phone is malfunctioning already, that is the best thing that you can do. You can check with your service provider if they can reflash the phone for you, they can do it for a couple of minutes.
Posted on Jul 31, 2009
I have an alcatel fierce one touch phone just went black? Fully charged.wont do anything? Help please!
Do the one two three method. While the phone is still on, remove the battery. Once it is removed, hold down the power button for ONE minute. This will drain any remaining power with the battery removed. After one minute of holding down the power button, replace the battery and see if it is still black, if it is, repeat only this time hold that power button down for a full TWO minutes and again put the battery back in and see if that fixes it, if it doesn't then do the same for a full THREE minutes. Basically you need to drain any remaining power from the phone before putting the battery back in to fix the problem. Hopefully this will fix your problem.
Jan 09, 2017 | Alcatel Cell Phones
My alcatel fierce just went black. Fully charged, wont do anything?
F&P GWL11 Washer Stops at rinse - Error Code 37
I hate to say it but it sounds like the controller. I used to have one that had a similar problem that was fixed with a diverter and a controller. Another year or two later it was doing the same thing, so we just replaced it. Just a warning.
Jul 08, 2012 | Fisher and Paykel Washing Machines
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
Our unit is beeping every 30 seconds repeatedly no matter where we put it in the house. Is this carbon monoxide or the need for a new unit? We tried replacing the battery.
Probably not Co. However, try taking it outside (if the weather is not extremely cold) to see if it stops beeping. Remove the battery first, though. Then reinstall it once you're out side. It May beep initially, but should stop once it senses clean air. Are you receiving an error message or code of any type when this occurs. If you do, check your Owners Manual for this code.
FYI - There have been repeated problems with this specific unit. Generally, the Kidde Company will tell you to return the unit to them for repair or replacement. Once you contact them.
Jan 28, 2011 | Kidde Nighthawk Combo Gas/co Detector
My shuffle stopped working when i sweat all over it
Based on your detailed post, I think it's toast. Liquid + electronics + power (repeatedly and attempting to charge it too in this case) usually = toast.
Sorry, you can try to let it dry out (without attempting to charge or power on in a dry environment) for an extended period (a week or so in this case) and then try to charge and power it on again, but it's recommended to do this (and remove the battery when possible) as soon as the liquid contamination is realized.
Jul 15, 2009 | Apple iPod shuffle MP3 Player
Hardware may be
first of all do one thing and that is keep your platen marked A,B,C in b or c position then start printer if it prints then it means your shuttle gets very much tight in position A, for that please switch off the printer remove paper and loose your shuttle and adjust your shuttle according to the movement of paper. also do one thing that is clean your shuttle senser also.
Feb 19, 2009 | Printronix Line Matrix P5005B Printer
Code for dvd player dvd252
Pioneer DVD player (DV-505, DV-525, DV-606, etc.) Note: Some codes work on LD/DVD combo players only, such as "Disc side A/B".
Note: The LD/DVD 0525 code will work too, but the arrow keys (among other things) won't work without being keymoved to the correct codes.
000 Chapter prev
002 Pause
003 Scan reverse
012 Disc side A/B
014 Random
028 Power on/off
029 Step/slow reverse
030 Audio
031 Exit?
033 Menu
034 +10
035 Power off
061 Power on
062 Power on
063 Demo (when player is off)
064 Power on
067 Reset (when player is off)
076 Program
077 Repeat A-B
078 Disc side B
080 Disc side A
082 Enter
084/086/088/090 Shuttle reverse
085/087/089/091 Shuttle forward
092 A/D/CX
093 8
097 9
140 Return
142 Last memory
143 Up arrow
147 Down arrow
150 Subtitle
156 Title
157 Mode (set-up)
158 Open/close
160 Angle
161 Condition
162 Step/slow forward
163 Chapter/time/frame search
191 Chapter next?
195 Chapter prev?
196 Right arrow
203 Left arrow
204 Repeat
205 Time search
208 Clear
209 Chapter search
211 Display
212/214/216/218 Jog reverse (w/still)
213/215/217/219 Jog forward (w/still)
220 4
221 0
222 6
223 2
224 5
225 1
226 7
227 3
252 Chapter next
253 Stop
254 Play (will turn on player and resume if player powered off)
255 Scan forward
Jul 11, 2008 | Televison & Video
Black lcd screen when switch on
i had the same problem and couldn't find an anser anywhere, so i just hit it.
seems to work fine now :)
Jul 11, 2008 | Canon PowerShot S1 IS Digital Camera
Computer won't turn on
tnielsen
u did not said ur mother board vander name and chipset. because some mother board can not star if CMOS battery expire. remove CMOS battery check it voltage bellow 3V or not if it's voltage bellow 3V then replace it. and try to trun on ur shuttle.
Jun 29, 2008 | Shuttle 200W Internal Power Supply for...
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
