Question about Onkyo TX-DS676 Receiver
Onkyo tx-ds676 dead no power up
Hi Experts
i have a tx-ds676 and it´s connect to line the red led at power buton comes light but wend i try to push the staby /power button the receiver doesn´t work no relays actuation i see all fuses and all of them stay ok but no power up came any body help me??
  • 1,512 Answers
Power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Posted on Dec 10, 2007
Stick your finger in your mouth plug your nose and blow real hard...this works
Posted on Mar 22, 2008
check that you have selected that option on both player and receiver.
optical setting. a lot of systems are defaulted to hdmi
Apr 12, 2014 | Onkyo TX-DS676 Receiver
I have been using dolby 5.1/dts in this machine without any problem till a couple of weeks back but suddenly it does not pick up either mode-all it keeps saying is it is set to dolby pro logic. Any ideas?
Which source(s) do this? Only multichannel digital audio in will light up those modes. Perhaps a setting in your source is the problem or your digital cabling is loose/defective.
http://www.retrevo.com/support/Onkyo-TX-DS676-Receivers-manual/id/365dj193/t/2/
I'd go through the digital input setup to make sure the receiver is set the format to Automatic for everything unless you have an overriding reason to set it manually. Page 29.
Jan 16, 2011 | Onkyo TX-DS676 Receiver
Memory loss TX-ds676 onkyo
Ik have the same problem as Toolathep.
Is there a solution for it?
replacing the battery?
Feb 07, 2008 | Onkyo TX-DS676 Receiver
Power on
throw it in the trash and get a sony brand reciever.
Nov 04, 2007 | Onkyo TX-DS676 Receiver
Onkyo TX-DS939 Receiver Problem
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Nov 04, 2007 | Onkyo TX-DS939 Receiver
Right front channel sometimes does not work
you have dry solder joints in the output stages to the front channel.-solution. resolder channel.... or dirty speaker protection relay contacts. can be determined by tapping the top of the protection very gently when fault occurring. solution. burnish contacts and treat with crc2-26
Oct 20, 2007 | Onkyo TX-DS676 Receiver
Onkyo TX-DS676 Receiver Logo
558 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
