Question about Intel D845GVSR Motherboard
Case wires two motherboard
Need help with puting wires bach in place
  • cradle Aug 05, 2008
    i need help putting the wires backin place
    Problem Solver:
  • 7 Answers
This is the answer
Posted on Jan 30, 2008
When was my vintage Selmer Bundy cornet manufactured serial number is 404986 usa
Here is an ebay link to a similar item, for sale (including date):
1989 Vintage Bundy Selmer Cornet Trumpet Designed by Vincent Bach with Case ' eBay
Jul 13, 2014 | Selle Italia Cycling
Why button PrtSc doesn't work?
either a wire wrong or a snall error in the motherboad ? also had problrems withmotherboaods that couldnt be fixed like gigabite , send the board bach for a refund or a new 1 that was tested
Jun 10, 2014 | Lenovo Computers & Internet
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
Where does the power switch plug into on the motherboard, along with the two other plugs grouped in those wires?
to answer this question, your really need to know the motherboard type and name, as in some rare cases the switch does not plug into the same location as all other motherboards. In most cases though, looking into the computer case, on the bottom right of the motherboard there will be a place about 1/2 inch wide and 1/4 inch tall will 8 to 10 pins. That is where the switch will plug in. Knowing exactly which place to plug it into though, comes back to needing to know the motherboard type and model number. Then on the motherboard manufacturer's website, you should be able to find a user's manual about the motherboard, and in there there will be instructions as to where everything plugs in.
Feb 12, 2010 | Everex GA3400 PC Desktop
Im not sure how to wire the front buttons to the motherboard.
normally the wires black connectors are marked with white text like PWR SW and PWR LED and stuff and the colors of the wires normally correspondes to the color on the motherboard.....ill look it up and see what i can do for you!
Aug 13, 2009 | Intel Desktop Board D845GERG2 Motherboard
Case wire two mother board
Here is your front Audio guide:
Here is your USB guide:
And here is your front Panel guide:
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
ECS 755 A2 motherboard problems
Make sure you have the correct front panel header connected correctly to the case wires. Open you're manual to page 12 under the English section. There you'll find a picture of the front panel header & how to connect the case's LED's to the motherboard.
If you no longer have the manual you can download it from ECS at this link.
Chances are you may have the wire's connect backwards. (Positive + connected to the negative - ECT).
Example, pin 1 is the + for hard disk drive & pin 3 is - for the hard disk drive. Cases vary on wire colors, normally if each connector has a common colored wire (solid color) that common wire would be the negative. Stripped wires are negative. Other cases use white colored wires as negative & colored wires as positive. As far as you not receiving any display. Try removing the AGP card & clean the copper contacts. Clean with alcohol.
Place a couple drops onto a cotton swab & clean the copper, both sides. Blow out the AGP slot with canned air. Re-check all connections, power & data cables before closing the case. Power on the system & check the front led's for operation.
If you still fail to get display, re-check the connection from the monitor to the case. Try you're monitor on another system. If good than you're video card could be bad. You're motherboard can run an 8x/4x speed AGP 1.5volt (only) graphics card.
Good luck zeratu_l !
Need more help? Post within this link.
Jul 28, 2008 | Computers & Internet
No place to plug in case power/reset button plugs on k7vm3 motherboard... And some other case wires too =(
here is the link for user manual for your motherboard
you will find the answer for reset button in page 17
but no place unfortunantly for you case power
Apr 07, 2008 | Asrock K7S8XE+ SIS748 (K7S8XE+RAID)...
I need help puting it together
if you are using the generic or compatible casing it is written in the connectors of the casing (power sw, reset sw, h.d.d led etc.) and in the motherboard you can see also the markings or labels. it depends on the motherboard brand and design just follow the manual.
Mar 16, 2008 | Computers & Internet
What motherboard? State your question in a more complete manner, not like a kid in kindergarten
Nov 24, 2007 | Computers & Internet
Intel D845GVSR Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
