Question about Bosch Washing Machines
Need to no how to open washing mechean - Bosch Washing Machines
  • 23 Answers
YOu cant' Crappy design if you ask me... There is no Pause on the Boch washer... Once you start the load, the load must either be finished, or you have to cancel out the entire load and start over. What ever you do, DO NOT turn the nob... Let the entire cycle run through, then the door will open
Posted on Jul 30, 2009
We have a dometic wmd1050 front loader washing machine in caravan we did some washing today went through washing cycle ok lights went out on door lock but can't open door how do we open door
The latch assembly broke so you will need to use a screwdriver to manually release the latch. It will not be easy to get the door open, you will need to get in behind the latch and pry slightly to the left. The parts breakdowns are available below so you can see what you are up against. See the 4th page at the URL below.
http://caravansplus.com.au/pdf/WMD1050-Spare%20Parts.pdf
Apr 17, 2017 | Washing Machines
Door will not open after washing cycle ends on SamsungWF8704RSW washing machine
If water still in machine saftey feature will not let door open. Machine may have been over filled with washing, or filters may need cleaning, or both. Set the machine to do another spin cycle, sometimes needs to beredone several times. Clean your filter in normal way but be careful as water in drum could drain through filter.
Sep 15, 2016 | Washing Machines
Washing machine stuck on e16 error need to get washing out please help can't it won't unlock
The only way is to disconnect from power if the door does not open within the specified time then you need to open the top of washing machine and get access to the electronic switch then tak it off do this without power this will open the door and if can test the swich if faulty you can get replacement from washing machine spares on internet google it hope this helps
Mar 05, 2016 | Hoover Washing Machines
Lumina front loader washing machine door does not open
You need to check your filter criteria you have probably got something wrapped around it.the filter is generally on the right hand side at the bottom you need to remove it by inserting a tool that fits into the slot and turn anti clockwise.good luck.
Feb 22, 2013 | Washing Machines
I have a 2000 mercury cougar and my back wiper works but my front wipers doesn't
check fuses. both wipers use a different fuse. If you hear noise when you turn on the wipers but they wont work, it usually means that your wiper mecheanism has come off the motor or the motor needs to be replaced
Sep 27, 2010 | Mercury Cougar Cars & Trucks
Automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
UNABLE TO OPEN DOOR AFTER WASH
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Apr 08, 2010 | Hotpoint Aquarius WD640 Front Load...
The washing machine doesn't open if I use detergent
read the side of the detergent box it normally says how much, and your washer is probably not opening because it has lid lock to open it you need to pause the cycle and wait a few minutes and it will release the lock also if the washeer is spinning or agitating the lid will automatically lock to open do as described above
Feb 19, 2010 | Asko Washing Machines
Cannot open door Aquacycle 1200 washing machine. The handle and t
If you unplug the unit, take off the top of the unit and down the front of the you should be able to see the door lock (interlock) from inside the machine. You need to push the door latch out of the lock firmly it should pop open. cheers
May 14, 2009 | Washing Machines
Washer
if youd like to open the calypso while running,Id assume to add clothing, hte machine will pause the cycle, and youll need to press the start/resume button, but it shouldn to have to restart from beginning of cycle
Mar 16, 2008 | Washing Machines
Open Questions:
Bosch Logixx 8 washing machine Powers OFF itself when filling water in the softening stage I have a 7 years old Bosch WAS32742AU/08 washer, it will wash, rinse then will power itself OFF with nothing on the display when it reaches the softening cycle where it begins to fill water, there is about 10mins left in the cycle. I can turn the dial OFF then back to the same program to resume the cycle, it will start filling with water again in the softening stage and power off again. I've checked the water level pressure switch hose and cleaned the chamber, I dont't think there is a problem with that because it works during the cycle until the softening stage. I can run and complete the Drain only cycle, Rinse only cycle, Spin only cycle and 15min Quick cycle without interruptions. It's only programs that has the Softening part of the cycle it powers off when filling water in the middle dispenser compartment during the softening stage where Valve 1 and Value 2 are open. I don't even use softener and the compartment is clean. The current work around is when it Powers OFF during softening, I turn the dial to OFF then select the rinse only cycle to complete the washing. I got into the Valve test mode and found that Value 1 and Valve 2 tests are OK individually but when it V1 and V2 are both ON to fill the middle softener dispenser compartment it wont stop filling and eventually the machine powers off. I posted a video of the test here: https:/ / streamable dot com/n1gw6 https:/ /player dot vimeo dot com/video/264199360 Do you know what the problem could be?
Apr 11, 2018 | Bosch Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
