Question about Nintendo Video Game Consoles & Games
My wii remotes wont pick up signal blue lights flash then just go back out again
  • 315 Answers
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
my wii remotes wont pick up signal blue lights - f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii consolmy wii remotes wont pick up signal blue lights - rtemagicc_installation_02.gif.giffixya.net/uploads/images/rtemagicc_installation_02.gif.gif" alt="rtemagicc_installation_02.gif.gif" class="h_mi" />
    2. Selmy wii remotes wont pick up signal blue lights - rtemagicc_homesmall_02.gif.giftion from the Home Menu.
    3. The battery level of all synced Wii Remotes is dimy wii remotes wont pick up signal blue lights - rtemagicc_wiiremotesynchotm1_02.gif.gificates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and my wii remotes wont pick up signal blue lights - wiiremotesynchstandard.gifhe inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Posted on Jul 30, 2009
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
My wii wirless sencor bar has a blue light on but wont pick up my wii remote
Perform a remote power requirements check. For example, check for batteries in remote control compartments, replace with fresh new batteries for desired operations. Alternatively, the remote control would require power on buttons before functioning with NIntendo. Locate controls power button to initatiate process.
Jan 11, 2011 | Nintendo Mini Wireless Sensor Bar for Wii
My two wii remotes wont power up ,the charger is blue but when you press the power button on the remote all 4 lights at the bottom of the remote flash. what is the problem please?
You need to sync them again. To do this you must first press a little red button located in the front of the wii next to the sd card slots. Hold down for about 2 to 3 seconds. Right after wards look on the back of the wii remoter and take of battery cover. Press the tiny red button on the bottom left hand corner to sync to the wii.
Dec 31, 2010 | Nintendo Wii Console
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
My wii fit board wont switch the blue light flashes then goes off
Unplug the AC adapter on your console out of the Power cord then wait 15 min and plug it back again.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Fit and push the red button there.If this not help press and hold the red button on your Wii for 20 seconds.This will clear all synced Wii Remotes from the console.Then repeat the procedure again.In this case you need to SYNC your Wii Remote too.If this not help your Wii Fit may need service.
Nov 03, 2009 | Nintendo Wii Fit - Balance Board + Game...
Drums wont connect
go to the wii counsule and open the little hatch anpress a red button then press a white dot on the back of the wii remote
Sep 16, 2009 | Nintendo Rock Band for Wii
Wii Problem, the remote
make sure a combination of the 4 blue lights at the bottom of the remote are on (but not flashing, mind you). if they're not, this means that your wii remote isn't connected to your nintendo wii system yet. if when you press a button and none of the lights turn on at all, this means that there are no batteries in your wii remote. if it flashes, this means its trying to connect to your wii system. you might have to troubleshoot this a little bit. try to aim it at the bar that recognizes the wii signal (a separate piece that comes with the wii system).
hope this helps ;-)
Apr 04, 2009 | Nintendo DS Lite
My wii remote wont go on even i got new batteries
You have to press the sync button in both the remote and the back of the wii.
Aug 13, 2008 | Nintendo Wii Console
My wii remote wont work
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jun 21, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
251 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
