Question about Canon PC-920 Black and White Copier
Pc920 won't make copies
I have a pc 920 had forever just decide to use turned on and it makes a lot of noise. Then you can' change any of the specs on it. Push copy and the copies get stuck. I don't won't to invest in a cartridge if its not going to work
  • 313 Answers
The noise could be the heat rollers have squared of this happens if the machine hasnt been used for a while the pressure makes a flat on the soft roller.. it cold also be the toner cartridge has settled. take it out and give it a good shake.. if you cansee if the scanner lamp and carriadge is moving when you run the copier up it mighht be saveable.. make sure the paper is new and dry as this can cause jams in hot section.. if you can see where the paper jam is when you do one copy check the guides as well and finally take the paper tray out and look at the condition of the rollers that feed the paper as they may be dirty and sliping the paper..Good Luck A
Posted on Jul 31, 2009
Copy machine - canon PC920 leaves black streak in middle of page - on copy
Check for white-out or some other dirt on the scanner head, the piece that moves from top to bottom to scan the item to be copied.
Feb 18, 2017 | Canon PC-920 Black and White Copier
New Cartrige Installation PC920. Blank pages. Is there a shield or seal to remove?
There is a tab on the drum unit that when the drum is inserted into the copier moves the laser shield out of the way. This may be broken off.
May 06, 2011 | Canon PC-920 Black and White Copier
Can I replace the start button on my canon pc920 myself?
Your start button is a small microswitch that is soldered to a circuit board. If your mechanically inclined and can solder, then you could probably repair it yourself. The green plastic button you press, in turn pushes this switch and the switch itself starts to go bad after a time. You can even, as I have done many times, simply move a switch from a function that is rarely if ever used, to the print switch location so you don't have to go out and try to find the proper switch.
Oct 23, 2009 | Canon PC-920 Black and White Copier
How do i replace the fuser fix film in my canon pc920
How do you do. If you never changed the film, I you do not advise. This will occupy beside you much time and sooner whole, you her(its) damage. This repair is considered complex. You should apply to service Canon. If you interesting, call at on site - only fragments,regrettably, in russian language only. On put you are able to find much interesting, including on angliyskom.http://www.startcopy.ru/likbez/tp_ir1210.htm
Oct 06, 2009 | Canon PC-920 Black and White Copier
My canon copier pc920 is displaying a EO message in the LCD screen. What does this mean?
E0 for PC 920 - Fuser problem?or temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc ((( its work for a sevice...
Jul 26, 2009 | Canon PC-920 Black and White Copier
Canon pc920 black and white copier white streak on copy
PULL OUT THE TONER CARTRIDGE AND SHAKE IT, IF THAT WORKED A BIT BETTER THE CARTRIDGE NEEDS REPLACED.
Apr 07, 2009 | Canon PC-920 Black and White Copier
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
Toner Cartridge
Mine is a single cartridge system. The black cartridge that looks like it holds the ink is the toner cartridge. Replace it with cartridge E40.
Jun 12, 2008 | Canon PC-920 Black and White Copier
Canon PC-920 Black and White Copier Logo
114 people viewed this question
old marine
old marine
