Question about Dryers
Ive got power, timer and heating elements work but drum wont spin?
  • Dryers Master
  • 1,606 Answers
Broken belt .
Posted on Jul 31, 2009
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Whirpool dryer, no heat, timer is not going right
no heat and the timer not operating is an incoming power problem,shut off and reset the breaker or check both fuses at the power panel in the house,the element needs 240volts a.c. to heat and the drum motor that turns the clothes is on one side of the 240volts which will be 120 volts a.c. and the timer is on the other 120 volts a.c.,if you lose either phase either the timer or drum motor wont turn and for sure it will not heat up,also check the neutral terminal wire inside the dryer for burning off as it carries all the return current from both phase power wire,if this opens tho it will only heat and no drum or timer operation
May 29, 2011 | Whirlpool LER4634J Electric Dryer
Dryer does not heat up. Air dries, timer works, drum spins, but no heat.
Your heating element is bad go to a maytag or whirlpool servicer and get one for about $50. this will Fixya
Nov 08, 2010 | Maytag Dryers
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
Jun 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Apr 13, 2009 | Asko T701 Electric Dryer
Indesit w113 washing machine
check heating element (rear of drum at the bottom) for open circuit, replace if needed, occasionally the timer will start to click round continuously, indicating the machine has a fault, the machine shuts down waiting for the water to heat up, elements available at most appliance shops but you may need to order specially?
Sep 01, 2007 | Washing Machines
Dryers Logo
46 people viewed this question
Top Dryers Experts
