Question about Sewing Machines
Felt washer at oil points on shaft or gunk?
Cleaning a friends Elna Pro 5 machine (She just inherited it). Was a real mess. Where you oil the shaft thing in two places, is there supposed to be a kind of grey felt washer around the bottom of the shaft. It seems to be attatched so I didn't want to assume that was gunk and clean it off.
  • 26 Answers
Yes, oil them very thoroughly
Posted on Aug 06, 2009
I have an Elna Carina SU sewing machine and it will only sew in very small stitches and can not adjust it what is the problem
sounds like the needle bar is gunked up, has it had a service recently? ie the past two years. Has it been used regularly or has it been away for a while and now pulled out and found this problem. All machines if left for a while, internally the oil dries up and that combined with any dust or lint forms a real gunk on the moving parts. Often this results in no swing on the needle bar, ie the machine will only produce a straight stitch, no needle swing. Take it into the shop for a good clean and service.
Dec 26, 2014 | Elna Sewing Machines
Standard tension setting
I can't see your model listed, only Elna Sewing machine, which may be one of the newer ones or could also be an older Swiss made. machine. So, can't tell if you've got a top loading bobbin where the bobbin case is integrated into the machine. Or some Elnas such as the Contessa and Primula were a front loading bobbin in a case, these are a bit different in setting the lower tension.
But generally, you shouln't need to mess with the lower tension, and top tension should be in the range of 5, sometimes 4-6 depending on what you are sewing. If you are having top thread issues its more likely to be a gunked up tension device or something missed in the threading path causing the issue. If you can add in your actual model I may be able to assist more specifically.
Aug 26, 2013 | Elna Sewing Machines
I inherited an Elna 2002 and I can't figure out where the spool of thread goes on the machine. There are two round metal pieces surrounded by a piece of felt on the right side of the machine but nothing...
Can you pull the metal pin up, I know that the Elna 5000, 7000 and 9000 all had retractable thread spool holders. There might be a little lip on the edge of the metal pin that you can grasp with your nails to extract it upwards.
Apr 27, 2011 | Elna 2007 Mechanical Sewing Machine
I just inherited an Elna 2002 machine and I can't figure out where the thread goes on the machine. I've looked at pictures of the machine but there's not a holder on my machine for the spool. There are...
tally_girl_22.jpg You need to pull them up from the retractable position for storage and transport, many Elnas have the retractable thread spools like this to protect them from breakage.
I have a old old elna Stella 27 and it's a beauty but I am having problems with the lower thread tangling until it is a thickish mass around the outer side of the place the bobbin goes, but then sometimes...
Hi! Congratulations on your old Elna! I just love old sewing machines; they are so solid and reliable.
(Unless of course you're getting a big bird's nest with the bobbin thread, right? That's so frustrating!)
With my old machines, I've found that a tiny bit of thread caught in the bobbin assembly can cause these nasty tangles. I use a bright flashlight and a pair of tweezers and just keep looking until I find it. While you're in there, clean out any old lint or gunk (meaning, old oil) you find. Brush all the lint out. I use a q-tip moistened with a bit of WD-40 to clean the gunk (but be careful that the fuzz from the q-tip doesn't come off while you're cleaning). With the WD-40, you have to be very careful not to get any of it on the surface of the machine--it can mess up some of those beautiful old finishes.
So clean the bobbin area, make sure you're threading the bobbin correctly, and lastly, if you hold the tails of the top and bobbin threads snugly in your left hand behind the needle while you take the first few stitches, the birds' nests should be a thing of the past.
Let me know if this works, ok?
Happy Sewing!
Feb 10, 2010 | Elna 2007 Mechanical Sewing Machine
Elna Pro 5 DC
Yes I have one, can you tell me where can I get parts for my Elna Pro 5 DC?
Nov 01, 2008 | Elna 1010
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
