Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Missing two handle attach nuts .
I bought this vac. 11-23-07, when i was making sure it had all the parts i noticed it was missing the two nuts that attaches the handle to the body.
  • 1,673 Answers
Re: missing two handle attach nuts .
It is under warranty, call the 800 # in your manual and they will tell you who in your area to contact. Either that take one of the bolts to a hardware store and find the right nuts for them.
Posted on Feb 05, 2008
0 characters
3 Points
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at:
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
I just purchased this Hoover Steam Vac and am putting it together. The screws that attach the top piece to the bottom piece have washers that are stuck part way on the screws. Now I can't attach the...
I have assembled many of these machines, and have never seen any washers. There should be a small plastic bag containing two long bolts, two nuts, and a small self tapping screw. The bolts go through the handle assembly from the front, and the nuts fit into the upper hose holder from the rear ( you will see two hexagonal holes for them). The small screw holds the lower hose holder to the lower rear of the machine.
Jul 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Just receved this steam vac and noticed the floor was still very wet after using on a small area. looked at bottom and it has the one long stright row of brush and nothing behind(large gap, with some...
If their is problem with the sucction,you should clean or replace the bag seen inside your vaccum cleaner
If any basic part of your vaccum cleaner lost excludes brushes and cleaners you can't use it.
Feb 15, 2011 | Vacuums
I just got the steam mop but it came without instructions, I don´t know how to assemble it. I´m not sure if I´m missing pieces
There should only be 3 basic pieces to this machine. The body housing, the top handle and the floor nozzle. The handle attaches to the body with a bolt and a nut and then the floor nozzle is just pushed into the body housing. That should be it.
Nov 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Model number U5763900 Serial Number 090400013588 Handle broke off just above the four screws that attach it ti the boby of the vac. Hoover does not list parts for models that are more than two years old....
Generic problem for all Vacuums
Posted by rlholif on Jun 09, 2008
Model number U5763-900 Serial Number 090400013588
Handle broke off just above the four screws that attach it to the body of the vac. Hoover does not list parts for models that are more than two years old. The vac operates perfectly but without a handle my wife cannot use it, where can I find a part replacement. Easy to remove four screws and replace. Don’t want to drive 100 or more miles to find an authorized repair shop. Oh yes, this is a Hoover Preferred Wind Tunnel Bagless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You have all the information needed but I would contact your local vacuum cleaner dealer and they may have a good used one or they may stock a new handle for your you or they can ship you one If you live too far from a factory authorized dealer. The vac shop that I worked in always had good used parts for ½ the price and it worked just fine – the only difference was the color and for the handle that would not make a difference in the performance and your wife could use the vacuum again. Also Hoover can ship the part to you providing they have it in stock. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
Sep 01, 2007 | Craftsman 17026 Wet/Dry Vacuum
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
