Need a diagram for this overcomplicated machine
Need a diagram for this grossly overcomplicated machine (no output after an electric water pump switched itself off after all the water was pumped). Replaced ''blown'' delta capacitor but still negligible output of 2 volts per coil or winding. When field winding of 230 ohms is excited with a 12 volt car battery, voltage is produced briefly as engine starts up but voltage then dies away. Tried Chinese-copy regulator but still no output. Now noticed other black boxes as well. What are they for? Actual alternator is a Sawafuji M50.
    Problem Solver:
  • 3 Answers
Will probably bin it. Long experience shows that the ONLY alternators worth having are the British made Newage-Markon which IMHO are superior to both Sawafuji and Mecc-Alte. Voltage Dependent Resistors (VDRs) also known as Transorbs are essential if long term reliability is desired from small gensets. Haverhill Generators get around the voltage spike problem another way - 8 microfarads across the output but one Haverhill generator that I repaired had vibrated apart its control box wiring and fan. These little machines all leave a lot to be desired unfortunately and seem to give endless trouble.
Posted on Jul 31, 2009
WMH1163XVD seems to no be on full power. Takes 1 minute to heat up a piece of bacon
1 minute to cook a piece of bacon sounds pretty fast, really.
Try this:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
If the oven is grossly underheating or overheating, then you probably have a bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 18, 2011 | Whirlpool WMH1163XVS Microwave Oven
Water output too slow
Try to see how long takes whout coffee. If it is ok then the coffee is too fine or wed or the filter inside the holder need cleaning remove filter and wash it with hot water and brush so all holes to be open.
If after this you still have slow water without coffee the the pressure pump is not working properly and it need ither descaling or is complete damage so you need a new pump. Good luck.
Please remember to vote for this answer thanks
Feb 14, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Won't drain need diagram for washer
If you need to know the diagram is found in control panel .Check for voltage to pump also make sure a sock is not stuck in pump .
May 18, 2009 | General Electric WCSR2090D Top Load Washer
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
May 11, 2009 | Saeco VIA Venezia
Whirlpool LDA6900J0 Washer will not drain
LD is long drain error.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Dec 29, 2008 | Whirlpool Washing Machines
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Nov 15, 2008 | Dishwashers
Diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Nov 02, 2008 | Amana ALW480DA Top Load Washer
Water output hose
normally, they are just clamped to the outlet of the water pump. but be aware that you still need to raise the part of the hose as they come out of the unit in order for the machine to work. if you leave the hose just lying on the ground,as the machine fills up, water would be leaking down the drain even though water pump is not running. pressure switch will not be triggered and machine will not run.
Feb 18, 2008 | Whirlpool LBR5432PQ Top Load Washer
Thermostat does not stop heat pump unit
Most of these problems are the program settings on these way overcomplicated thermostats. You will need to re-read the instructions on setting the programs. Or bite the bullet and buy a cheaper and simpler one. If you installed it yourself, make sure the settings on the inside are correct, like gas/electric heat, and 24 volts, stuff like that.
Jan 22, 2008 | Honeywell Programmable Thermostat Heater
428 people viewed this question
k24674
