Question about Refrigerators
Auto defrost not working freezes up every 3-4 weeks and i have to defrost manually.
  • 2,418 Answers
Not knowing the Brand and or model is tough to nail down the problem. But if it is not defrosting then the first part to track down and replace is the timer. The controls like this are located in the refrigerator side close to the thermostat and the heaters and terminator switches for the defrost are located in the freezer section.
Posted on Jul 30, 2009
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Apr 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Self defrost not working condensor in freezer freezes up every 3 weeks or so
The auto defrost works from a timer which shuts off the compressor and heats up the cooling coils to clear up the frost in the coils. So if this wont work then your efficiency drops down. Hence trace the circuit from the thermostat, the timer and the heater. There could be wire worn out by frost so check the connectors. If the timer is faulty check it out and replace. Get help if you are not familiar but keep this advice with you, Good day
Jul 31, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
The self defrosing fridge freezer is freezing and leaking inside of fridge, 3 weeks ago I melted ice in freezer and drain with hair dryer, worked for 3 weeks, now freezes agin?
You have a problem with the defrost system. There 3 components... heater, thermostat, and timer or adaptive defrost control depending how old your refrig is. Check heater and thermostat( located on the evapotator coils) with an ohm meter. The heater will have some resistance and the thermostat will be closed(must be cold). If these check good replace timer or adaptive control.
Mar 24, 2010 | Refrigerators
Just freezes every six weeks and i defrost it then it works for six more weeks this is a g.e select side by side
this may be a condensation problem that occurs when the freezer coil is in defrost mode. slowly building up moisture until it freezes in the box. then you manually defrost it dealing with the moisture giving it six more weeks to build up again. I would call GE and get there recommendations on the drain systems through their tech support
Nov 27, 2009 | Freezers
My refrigerator model #hmg6414 will freeze for
if the rear frz back wall frzs up id say you have a defrost problem. 3 things it could be a heater, a defrost thermostat or a defrost timer .
if the unit runs for 2 weeks good then stops and doesnt come back on. id say your timer is bad. usually located behind ref in rear btm.part # 68233-3 roughly 55.00-100.00 depending on were you live. if works 2 weeks good then rear wall freezes up then your heater or thermostat is bad. heater # 61001874 roughly 39.99-69.99 depending were you live and who u use. if defrost thermost part # 52085-29 roughly 29.99-49.99. again depending on who u use. labor between 85-175 .hope this helps you . the heater can be tested if you have a ohm meter touch each end of meter leads to each side of heater if you get a reading on ohms its good, no reading means bad heater thats if the rear wall freezes in back only. defrost thermostat cannot be tested properly.
Sep 16, 2009 | Admiral Refrigerators
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Defrost trey and drain keeps freezing and water leaks inside
Your auto defrost cycle is not functioning.    The refrig will work for a few days and then freeze up again.   You will need to determine the cause, from a defective defrost heater, defective defrost bimetal, or Defrost timer  (mechanical or electronic control board).
Mar 14, 2009 | Whirlpool GS6SHEXNL Side by Side...
Kenmore 71192100 frost free keeps freezing up
Hi. thanks for the question . The first thing i would do is clear the drain tube .that could be why the freezer ices up .too much moisture Clean the drain, And the coils at the back. thanks the appliance doc
Sep 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge freezer
Defrost timers usually cause this type of frost build up. However it can also be caused by the defrost heater and/or heater thermostat, and these items are behind the panels therefore not easy to get to. Also before you attempt to take the panels apart make sure the refrigerator is unplugged.
Aug 04, 2008 | Candy Freezers
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Nov 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
