Question about Philips 42PF9631D 42 in. Plasma Television
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
Probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Posted on Jul 30, 2009
Ambilight Issue
Never do anything to this set now. Contact the authorized service center for Philips. Gopakumar Gopalan Google
Feb 25, 2014 | Philips 42PFL7332D 42 in. Flat Panel LCD...
Ambilight screen
Should be a back-light problem itself. If you wish to know more about the back-light system of this Philips TV, check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. http://electronicshelponline.blogspot.com/
Jun 24, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
Ambilight isn't working when I press ambilight on the remote control. TV is about 5 years old
Have you tried turning it on in the menu options. Navagate thru the menu there is a setting for on or off on the Ambilights.
Jun 08, 2011 | Philips Ambilight 2 52 in. Flat-Panel LCD...
I have a Philips Ambilight 32 PFL 7623D model and the bulbs on one side of the tv are no longer working. Are they easy to get a replacement and if so where from and approximately how much??
It is unlikely that all the bulbs have failed at once and more likely that the ballast unit for that side has failed.
If they are available as a spare part they will be listed on ebay as the bakkast unit for your model/size TV or on the manufacturers web site through an authorized repair centre.
Hope that helps.
Jan 02, 2011 | Philips 32PF7321D 32 in. LCD Television
The philip 50inch plasma tv i own has ambilight on both sides of the set. the light on the left side of the tv no longer seems to be working. is it simply a matter of changing the light on the tv...
you must replace the circuit board that illuminates display....you will see two(2) boards that look alike...take back off tv and you will understand.....1 of the circuit boards is bad and must be rebuilt or replaced!!!ckt boards are on the sides of TV...only 1 of them bad they both look alike . gl
May 19, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50pf9631d ambilight has gone out on one side, how do I repair it with out paying philips (or an authorized dealer) outrageous rates, for a problem that has clearly affected MANY Ambilight owners? This is...
ok its possible it is the light itself which would be cheaper- or- it could be the ambilight driver- each ambilight has a driver that tells it to turn on supplys power etc-its not difficult to change-usually located on either one side and the lights all run from it or one on each side-depends- its small rectangular and you can follow the wire from the light back to where it plugs in to the driver- try shopjimmy dot com for parts
Aug 18, 2009 | Televison & Video
My flatscreen tv gets green dots that appear on screen while...
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Apr 07, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Ambilight bulb not working
can u change bulb if not workin
Oct 05, 2007 | Televison & Video
Philips 42PF9631D 42 in. Plasma Television Logo
852 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
