Question about Coffee Makers & Espresso Machines
Water pik is running but no water comes out?
I have tried viniger .......didn't work??
    Master:
  • Coffee Maker... Master
  • 739 Answers
First, I'm not a Water Pik technician. But I have worked on similar water pump systems for espresso machines. You should call your vendor or MFR for service. Especially if it's still under warranty.
*** the following is for information only ***
* These units have vibration pumps that force short shots of high pressure water in one direction. Hence the pulsing action from the 'Pik'. If the tank goes completely empty while in use then air gets into the pump and one way valve. Refilling the tank (full) and restarting the pump will help push the air out. It helps to hold the probe (Pik) end down to the sink. Be sure to keep it lower than the tank and unit. Keep turning the unit on/off until the air is purged and you get a regular flow. If you have a clear tube and note water drops only vibrating back and forth in the tube, then there is still a bubble blockage. Shaking the tube up and mainly downward may help.
* If the water (in the tube) only sits steady with no movement then the and you hear a loud buzzing sound (or no buzz at all) then the pump is bad and needs to be replaced.
* I recommend a complete replacement of the pump as it's very tedious to dis-assemble and service. (lots of very tiny parts) Here is a link about it (but it might be too much information):
https://www.bing.com/videos/search?q=vibration+pump&&view=detail&mid=2755F4CAAFABE5AB0B842755F4CAAFABE5AB0B84&&FORM=VRDGAR
Aloha, ukeboy57
PS; you might check with your dentist as they usually the ones that promote this stuff, or at least have a service contact. (in this case it really won't hurt. ;-)
Posted on Feb 14, 2018
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I tried to descaled with
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
GASKETS FOR WATER PIK SM-651 SHOWER HAND HELD
Fixya does not sell Water Pik gaskets.
Mar 23, 2018 | Water Pik Home
How do i fix my water pik water want come out
The filters need cleaning or there is clog. Here is a tip. Get some denture cleaner put enough water in it. And put 4 to 6 tablets and let it soak 24 hours. If you have no power the fuse is blown. Check the outlet by using another device.circuits in bathrooms will have a reset at the outlet. Possibility. Blown breaker
Feb 25, 2015 | Water Pik Home
The squirl-cage fan (MSZ-A15NA) clogs up with mold once a year, which drastically deminishes airflow. I have had the dealer technician come out and disassemble enough of the unit to gain access to the fan...
Instead of spraying vinegar, i would say spray wd-40 spray.That will keep the fan and its internal assembly clean and not let the fan movement get tight and rusted.It will not allow the parts to get tight and rusted.-------- But once you spray wd-40, you have to let it remain there for 30 minutes to 1 hour, then turn the unit on .The wd-40 spray takes time to show its effect.--------- The wd-40 spray is easily available at local walmart and homedepot stores or at appliance parts repairs store.---------- This will help.Thanks.Helpmech.
Jul 09, 2011 | Mitsubishi MSH09TW Air Conditioner
The coffey is coming out very slowly. i don't know how to clean the water filter/valve. thanx.
try pulling the filter plug out of the water tank run viniger through it and clean the tank were the coffee is the o-ring under the little screen gets dirty and you will know because it will leak on your counter top.
Feb 10, 2011 | Hamilton Beach BrewStation 47214 Coffee...
What home product can I use to descale
I have run 90% white viniger mixed 10% with water in my coffee maker.Run the mix several times trought the coffee maker, then run water to remove the viniger tast.
Dec 28, 2010 | Braun Tassimo Coffee Maker
Water does not seem to be getting to the heating area
I'm not sure if your saying it does not brew a cup of coffee at all or it is brewing but only cold water comes out. If it is just sitting there making a whinning noise and not delivering water it may just be dirty. To clean it you need to fill the resivior with a 50% white viniger and 50% water mixture. Run a brew cycle and let it sit for an hour. Then run several cycles through until it is out, refill the resivior with water only, run it completely through and continue with the water only until there is no more viniger smell or tatse. You will need to clean the brewer needle heads as well. Lift the handle to access the coffee pod compartment, remove the pod basket and use a paper clip to clean out the hole in the puncture needle. With the lever still raised, use the paper clip to clean out the three holes in the upper needle head. Replace the pod basket, close the handle and run a couple brew cycles through without a coffee pod.
Nov 24, 2010 | Keurig B100 Coffee Maker
Filter seems cloged
Have you tryed soaking it in viniger will clean shower heads.
Do you get a good stream of hot water through the shower arm with the shower head off. Take it off and make sure shower valve is suppling hot water.
Mar 06, 2010 | Water Pik & Wallmount Showerhead
Not cleaning properly
dont remove it try running white viniger thru it like you do your coffee maker. this probably a hard water problem. the same way you do the soap
Apr 26, 2009 | Dishwashers
How to clean a coffee pot with viniger??
Try 1 cup viniger fill rest of pot with water. run it through the machine. through away fill pot with water run through 2 more times. that should do it.
Apr 23, 2009 | Mr. Coffee TFX20 / TFX23 Coffee Maker
Machine makes coffee very slow. I have been using for 1 year.
mix 3 parts viniger to 1 part water and run through it a couple of times. Then run plain water through it twice.
Mar 05, 2009 | Salton EX20 Coffee Maker, Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
