Question about Whirlpool LER4634J Electric Dryer
Light is on when I open door, but dryer doesn't run
The light is on , but the dryer doesn't run, the timer doesn't move either, I initially thought it was a worn out timer and replaced it. didn't make a bit of difference. I have also reset the breaker in the breaker box for the house just in case that was the problem and would be a very easy fix, still not any better. please help. I have a Kenmore Dryer, model# 110.64642400 ,
  • Whirlpool Master
  • 1,606 Answers
Sounds like a bad thermal fuse ( a small white plastic piece located on the blower box with 2 wires connected to it ) .
Posted on Jul 31, 2009
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dyer will not start-Start button seems to be the problem
This may be your timer or your start switch may be bad. Hope this helps!
Aug 14, 2009 | KitchenAid KEYS700LQ Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
A common problem, had it happen to me.
Replace the timer control. takes about 15 minutes and the skill to remove screws, disconnect plug from old timer, remove timer, install new timer, connect plug, replace screws and panel, run dryer.
Reply the model number, and I'll get you the timer P/N.
Jan 15, 2009 | Kenmore 97572 Dryer
Kenmore model 110.63932102 Dryer will run, however the timer does not move. We also have to play with the start button to get it to start some times. Opening the door does not break the cycle and as soon...
1. Opening the door does not break the cycle
The door switch needs to be replaced
2. the timer does not move
The timer should be replaced
3. Start button
This could be in the start button or at the motor
Dec 17, 2008 | Kenmore Dryers
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
147 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
