Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge gas oven/ranger xl44
Set the oven temp, preheat beeps put food in oven a random amount of time and the oven stats beeping and flashing "F2". What does "F2" mean.
    President:
  • 878 Answers
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Posted on Nov 24, 2007
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
Oven pre heats then beeps with "F 2"
Hello,If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board.
If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically.
Thanks
May 28, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
F2 Code Problem
I can't take credit except searching and found this info.. I will order to see if it fixes my error messages..Tom
All, I hope that this helps everyone having this annoying problem. The problem is the F2 error that seems to come on everytime you use the oven. Well, it was driving my wife crazy, so I finally gave in, and had a GE technician come over to fix it. :) It cost me $190, with $80 for the part and $110 for the labor. Had I known what the problem was, I could have fixed it myself in 10 minutes, and only would have had to buy the part. My loss is your gain. The technician replaced the sensor, part #WB21X5301 (can find at (www.geappliances.com (http://www.geappliances.com)); cost is $76. If you open the oven door, the sensor is on the top left-hand side and is long and skinny. Instructions come with the part to replace it. Basically, you unplug the oven, take out two screws, and cut the two wires to the sensor. You then use wire nuts to connect the new sensor wires, and push the :) wires out of the oven area into the back panel. That's it. Problem fixed. Glad I could help out others!! Merry Christmas! JakeDecember 11th, 2005, 02:25 PMThanks for the information and update back on this problem you had.:)
You can also buy that same part#WB21X5301 from here, abit cheaper:
Oven sensor assembly (http://www.repairclinic.com/referral.asp?R=1265&N=252618)
May 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 True Temp F2 warning
I had the exact problem with F2 . I had to have the computer chip replaced. I do not know how much that would cost. We live in Military housing and they took care of it. I hope this helps.
Jan 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
426 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
