How do you print front and back of copies - Office Equipment & Supplies
  • tommya300
    tommya300 May 11, 2010
    what machine are you making the printing on???
  • 108 Answers
See if there is a duplex option on your printer driver or on the print job. Check the page setup box and see if there is a duplex option.
Posted on Jul 30, 2009
When I make a Duplex copying,it is copied at the wrong position only on the front side.
check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Oct 20, 2015 | Sharp Mx-2310u Color Copy/print/scan
My MX882 keeps feeding from back tray. How do I get it to print from front tray ?
Press the MENU button, select TOOLS or SETUP, select DEVICE SETTINGS, then plain paper feed settings and alter the settings to suit. This can also be performed from the computer from the printers and faxes folder (or devices in Win8). Open the printer window, click "Printer" then printer preferences and select paper source.
Feb 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
1 copy to front and back from computer
umm if I understand correctly you want one document printed same document on both sides select double side printing the where it ask for how many copies you want send to or how many of the documents you want in increments of two ex. 2=1 double side copy,4=2 double sided ,6=3double sided
May 21, 2014 | Kyocera CS-2550 Black and White Copier
I am trying to copy a 2 sided document to a 2 sided copy (just like the original). It makes the front page on the front and back of the copy.
Have you heard of duplex printing it should be under your properties in your printers pop up screen
this will give you a two sided copy ( Not sure if you have a document feeder) or a scan bed try an be more specific
Mar 02, 2011 | Office Equipment & Supplies
I AM TRYING TO FIND HOW TO COPY FRONT AND BACK PAGES.
copy the front page and when it prints, put the copy in the paper holder backwards and copy the back page. This new copy will have the front page and back page on the same sheet of paper.
Oct 07, 2010 | Canon imageRUNNER 2010F Copier
How do I use my printer as a duplex for making copies on both sides? Thanks Roxanne
The printer does not support duplex coping. If you want to do manual duplex copying, you can make a copy of the first page.
Then reinsert the paper upside down in the manual tray or paper tray, fil the page on the document feeder and make the back copy.
Aug 27, 2010 | Samsung CLX-3170FN All-In-One Laser...
My color copies have a black streak on the front and back of each copy. What can I do.
i have an lexmark 6500 all in one copier. If I print from the computer the copies are o.k., however, if I print a copy from the copier the copies have a black streak on them. How do I get rid of the streak on my copies
Nov 11, 2009 | Epson Aculaser C1100 Printer
Printed copy in correct page order- HP officejet 6110
Hi :)
This may work and its only a few simple clicks :) but it will take less time then re ordering you pages :)
IN the printer settings or Print preferrences there should be a tab for "Advanced settingings"
Go to Control Panel and select "Printers"
Select the general tab and at the bottom of the window select "PRINTING PREFERENCES"
another window will open
from here select the Advanced tab
Find Layout Options in the list
click it you should see "Page Order" and a drop down menu for front to back or back to front.
switch it to whatever order it is that you need and test it out.
or if that doenst work try this:
Set the most frequently used copy settings as the default. This includes changes to Copy Setup options in the menu system, as well as other front panel copy settings.
  1. Make any desired changes to the copy setup from the menu or the front panel copy option.
  2. Press Menu .
  3. Press 1 , then press 4 . The settings are now saved.
these are the only ways I have found to correct the problem.
May 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Photo Quality
Check the toner in your printer, It is either low or uneven in the cartridge. Remove the cartridge and gently rock it back and forward. Replace it and check toner levels. You can print a page with this on it fron the menu on the front of the printer.
Oct 16, 2008 | HP Color LaserJet 2600n Printer
191 people viewed this question
k24674
