Question about Motorola Mobility Z9 Cellular Phone
Never saved contacts to SIM, now have no screen....hoping to blindly store all numbers and put into new phone...help
How do I put phone numbers on the sim card
To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
Sep 02, 2014 | Sony Ericsson T707 Cell Phone
I have motorola v3 and the screen went bad .want to retieve my stored numbers . thank you
Numbers are either stored in the sim card or in the phone memory, if you need to restore them from the phone memory, you need to take it to someone, as you can't do it yourself since you can't see the screen.
Jul 27, 2008 | Cell Phones
My Nokia 2730 screen is broken so ave purchased new phone in hope of using original sim from it, however all contacts on phone? how do i transfre from handset to sim blind?
You can fix New Screen to your 2730 to Renew your Mobile screen Please Visit your nearest Nokia Service Center (Nokia Care) They will Put new screen to your Mobile then you can use your contacts to copy, you can move & every thing.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jun 21, 2011 | Nokia 2730 Cell Phone
"Nokia 6500s-1" Help, My Nokia
The one thing is, you should save it only once (whether its in sim or phone), and when you put the new sim, some handsets will ask whether you want to copy the contacts to phone or not and you might have selected yes.. so go to the phone memory contact and check those no, there might be duplicate nos in that, that might be the reason why you are not getting the name of the person on call. Save a new name and enter your another mobile no (which you never saved before), and call to your mobile from that another no and check.. hope this will help you..
May 13, 2011 | Cell Phones
The screen has cracked and can't get to any stored
get a new screen or follow menu guide from internet and do it blind
Mar 17, 2010 | Nokia 6500 Slide Cellular Phone
The light on my phone went out and i can't see anything but a black screen. if i buy a new phone and put the sim card from this one in it will i still have the same number and all the data stores on the...
Yes, the SIM card is what determines the phone number, so putting it in the new phone will have you set up immediately with your number and making calls.
But, sometimes contacts from the old phone were not set to be stored on the SIM. They CAN be stored on the SIM, but that doesn't mean they are always there. You probably have no choice, so try swapping the SIM to a new one anyway and see.
If the contacts and data didn't switch over, bring the phones to your AT&T (or T-Mobile or whoever you use) store and ask if they can transfer the data from one phone to the other for you. They have a machine they can hook both phones up to when the SIM card doesn't have the data saved on it already.
Dec 02, 2009 | Motorola Mobility TracFone C139-4 Cellular...
HELP!!!!
go into your you phone book settings and change the setting to save on sim card and that should automatically save them there then there's another setting where you can copy all the contacts saved on the phone to the sim to save putting all your contacts on the phone again hope this helps
Sep 29, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Sony ericsson k800i blank screen need to transfer numbers from phone memory to sim card
Thats a cool phone, pity its screen is broken.... Here is my suggestion
  • If you got keypad lock then unlock the phone
  • Go to menu usually by pressing the top right key...
  • Press 8, which should take you to contacts
  • Press the top right key which would take you to More
  • Press up using the joystick, this should highlight Options
  • Then press the middle of joystick, which would take you into options
  • Press up using the joystick again, this should highlight Advanced
  • Press 5 to backup the contacts to memory card or press 8 to back up your contacts to SIM
Check the memory card or Sim on another phone...
May 10, 2008 | Sony Ericsson K800i Cellular Phone
My old LG cell phone (LGCU400) broke and was replaced with a newer model (LGECU515). I put my old sim card in the new phone but I cannot retrieve any of my contacts/info from the sim card. Is there...
Hello!
I went to the AT&T/Cingular store and they tried hooking my broken phone to their system but could not retrieve any #s (they were saved to my phone not my SIM). They told me there was no other way to retrieve the #s and that a computer cable wouldn't work bc their system would've been able to retrieve them. I knew there had to be some way of retrieving them bc I could still turn my phone on- the top 1/2 (screen) had just broken off.
It finally dawned on me to look at my husband's phone (we had the same one), write down the buttons to press & the # of clicks per button on my old phone, in order to blindly go through my entire contacts list and save each one to my SIM card. Approximately every 25 contacts I saved I'd switch the SIM card to my new phone and make sure they were all saving correctly. I'm currently still transferring all 137 contacts- grueling but well worth it. This only works if your old phone will still turn on & function even if you can't see/use the screen.
***Make sure your phone's saving your contacts to your SIM and not your phone- I thought mine was and it was one rude awakening today when I found out otherwise! I hope this helps!
Apr 22, 2008 | Cell Phones
Ringtones
you have to saved your contacts on your phone memory and not the simcard...
1- enter the number in the phone ( press store)
2 - you will see in this screen the phone is asking whether to save to sim or to phone.
3- press phone
4 - no you see that the contact list hs more options.you can enter the person name contact numbers eg home,cell,work, email address, then scroll to ringtone.
5 - here now when you open the ringtones you can now apply a store ringtone to the contacts name.
hope fully it helps you :)
Jan 10, 2008 | Motorola Mobility RAZR V3
Motorola Mobility Z9 Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
