Question about Dyson Vacuums
I have a dyson v6 cordless stick. I have only used it about 10 times on a small bedroom. now there is a blue light blinking on the top part.
I have taken it apart and cleanded it, no clogs, nothing stuck. it still blinks blue, 10 times before the light shuts off again. I just purchased this in September 2017. thanks Chrissy
    Top Expert:
  • Dyson Master
  • 39,260 Answers
  • Defective battery
  • Defective charger
Posted on Feb 05, 2018
SOURCE: TH-42PX80U
i have the same problem but i have 11 blinks
Posted on Aug 13, 2008
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
  • 41 Answers
SOURCE: sony model kp51ws500
Yes common problem it seems with these. I can help you get the set working but this fix only prolongs the inevitable so I'm told. (more about that at the bottom) Please read entire posting before starting. You will need to take off the front panel, there are 2 screws towards the bottom on each side behind little pop out plugs. Once those are out take off the panel (pull from bottom, sometimes the round clips at the top come off, either glue them back on the panel or leave them out). There are wires attached to the panel, you can either unhook them or just take them out of the "twist tie" holders and move the panel out of the way to the left. You will now see a thin panel. Remove this one also. Once that is off you will see the bottoms of the 3 glass tubes and on the "floor" of the set there is a group of 6 small knobs. This is called the focus block. Each row of 3 knobs are labeled either screen or focus, also, there should be 3 letters R G B (Red Green Blue). (We won't be adjusting the focus knobs).You will need to adjust the Blue screen knob (on my set it was the bottom left knob). If the set will stay on for a little bit you can adjust it with it on. Once you have found the correct knob (don't worry about the white paint) turn the set on, once you see the picture slowly turn the blue screen knob counter clockwise until the blue diagonal disappear. Be careful not to turn this knob too fast while the set is on. Keep in mind, it may take a little bit to break off the paint. You will see the screen turn back to normal as you turn the knob. Adjust it just until the lines disappear This should solve your problem. If the set won't stay on, with it off turn the knob about 1/8 turn counter clockwise then turn the set on. Once it is on you can fine tune it. Adjust it just until the lines fade out of sight. (You may have to adjust back the other way until the lines show up and then back it off again). Remember to turn the knob slowly. I have heard people getting charged a lot of money for this. I was also told that this is compensating for a dying component(s) all I know it has bought me at least a year. I also read that someone has gotten several years out of there set w/o repair just by doing this adjustment whenever its needed. (once the lines start presenting themselves). I can't see spending big money on these sets when you could put it towards a new set so I will keep it going for free as long as I can. I hope this works out for you. I'm tired of typing so good luck and post if you need any more help. BTW this adjustment works if this symptom presents itself in green or red also. Just substitute the blue knob to the applicable color. Now go put your TV back together :)
Posted on Mar 13, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Posted on Apr 15, 2009
  • 3197 Answers
SOURCE: Garage door won't shut, light blinks 10 times.
If the light blinks 10 times it is a sensor problem. Nothing else will cause this. Tweak the sensor a bit and check it out.
Posted on Jun 29, 2009
I just got a dyson v6 stick and when I plug it in to charge thr red light blinks then goes off. a blue light does not come on.
The battery is either faulty or exhausted. See the instruction manual. Telephone the number and it will be repaired under the warranty, for free.
Apr 26, 2017 | Dyson Vacuums
Just purchased the dyson V6 animal cordless vacuum. We can't pull up and remove the purple filter by the tiny little knob on top. Is there a trick? It's brand new!
Hello, this is Ava with Think Crucial.
You may refer to the online manual below on how you can properly remove your Dyson filter:
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/V6_SV06_Absolute_Manual.pdf
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 28, 2016 | Dyson V6 Animal Cordless Vacuum
How do you remove the filter on the dysentery v6 animal Vacuume?
Ava B.
Nov 26, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
My Dyson v6 animal vacuum won't charge
Hello. I have the same problem as Shelly. My Dyson will not charge. When removed form the charger the LED light flashes a few times and then stops. The motor does not run at all. When the machine is returned to the charger the same thing happens. LED light flashes , then stops! The power supply from the mains plug is live. Any ideas please? From Eleanor O'Neill.
Oct 04, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
Charge only lasts a very short time, unit only 10 days old, should I hope last longer?
I would contact Dyson. It sounds like you may have a defective battery. Considering Dyson products cost an arm & leg, I would want this fixed/replaced under warranty.
Dyson customer service: 1 (844) 679-1647
https://www.dyson.com/contact.aspx
https://www.dyson.com/support.aspx
Apr 24, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
