You would first need to access your network. If you have wifi then scan for your wifi network name and select it from the network setup menu. Then you will need to enter the network password. Once that is done you should get a message on the screen that you are connected. If your tv does not have the Netflix button on the remote then you will need to find it in the apps section of the menu. Once you have accessed Netflix follow the log in menu.
SOURCE: LG Vu CU920 settings for cincinnati bell wireless
OK DIS IS THE WEB INFORMATION
ACCOUNT NAME:CBW Internet
HOMEPAGE:HTTP://GOOGLE.COM
CONNECTION MODE:TCP WITH PROXY
PROXY ADDRESS:216.68.79.202
PROXY PORT NUMBER:80
TIME OUT:150
NETWORK PROFILE:CBW Internet
SOURCE: i need an unlock code for nokia 6086 locked to cincinnati bell imei:354811010096438
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
