I have a Starlogic LCD monitor
And I get a message ''Out of Range'' For some reason it won't work on this one computer (with Windows Vista). However, it does work on a different computer with Vista. What could be the problem?
  • 20 Answers
You have definitely chosen a higher resolution than what your model of monitor could support , if you have a spare monitor please conenct change to regular 1024/768 resolution save it restart system and plug back this monitor and it should work , also you can try starting you comp on safemode and set the above specified resolution and try , do let me know what happens.
rgds
dil
Posted on Jul 30, 2009
Monitor displays out of range
reduce the screen resolution and then connect the monitor
Aug 12, 2014 | Star Logic Starlogic 17" Tft Lcd Monitor...
I do have a question, i was using old starlogic monitor (actually i have 2 of them, for now, 1st one is old, the second one is 'twin' ) i bought a pc emachine couple of months ago in april. any way. the...
What I have understood is that the resolution of the Windows is way too high for the monitor. Remedy. reboot in safe mode and when booted, right click on the desktop and select Properties->Settings. It will show you the display settings including the resolution. Reduce the resolution and keep the highest that the monitor can take. You may have to reboot a number of times. All the best.
Aug 22, 2010 | Star Logic 17" LCD Monitor
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
I own a StarLogic M17ANA Monitor...The screen is not working properly, displays "out of range". the monitor worked fine for nearly 2yrs., nothing has changed yet the monitor has stopped working. I was told...
hi there, the pro you talked to may be wrong in the first place as viruses tend to damage software programs(such as windows)
and not hardware(such as your monitor)
the problem maybe a different one, i am afrais you will ahve to see a tech about it...
good luck
Sep 06, 2009 | Star Logic 17" LCD Monitor
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
Problems with monitor
Are sure you plug into the right socket jack.
Try plugging different socket and listen.
Jan 19, 2008 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
