Question about Refrigerators
Samsung model rs2555sw. second digit of the fridge side display lit up with dash on top. What does this mean
  • appliancemed Jul 30, 2009
    I would like the manual. The outlet is grounded. I heard elsewhere this could be sensor problem somewhere and that is fault code. Have you heard this or know the code. Thanks
    President:
  • Refrigerators Master
  • 1,714 Answers
I looked up your manual, this is what it said:
Represents a ground is needed to prevent
electric shock. Do you have a grounded recepticle? If you need the
manual, let me know
Posted on Jul 30, 2009
  • Craig Butler
    Craig Butler Jul 31, 2009
    Here you go and please rate and close the question for me if you would be so kind?
    http://downloadcenter.samsung.com/conten...
What does the blue snow flake mean on the display
If the power /freezer is set the blue snow flake remains lit.
How do use the digital control panel on my Samsung fridge freezer
to turn off for normal operation and power save push and hold power/freezer button for 3 seconds.
Dec 23, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Where is the reset botton on a samsung rfg297 refrig fridg is totally out
There isn't one. If you had a brief power loss unplug it for 20 minutes and then plug it back in. It should restart. If this does not work.. Press the power cool and power freeze buttons for 8 seconds and then press the UP arrow to cycle through the menu. There will be horizontal and vertical dashes in the display if there are errors. NOTE the position of ANY dashes as they appear as there are actually 13 failure indicators via those various dashes. After the last menu the unit should restart. If it does not start after the menu wait 10 minutes to see if it restarts on it's own.
If you note dashes in the temp windows I need to know what window and what positon of the digital 8 indicator it was in. (upper, center, "top or bottom right and left sides" Top or bottom lines i.e exact digit as it would appear in a digital 8 display.
There are also things like the PTC relay, run capacitor or thermal overload that can cause this.
If you have no display at all.... your most likely looking at a control panel failure.
Thanks for choosing FixYa,
Kelly
Jul 05, 2011 | Refrigerators
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
Bot the fridge & freezer have quit chilling..
sounds like something pocked a hole in the refrigerant line ether inside or out side leak needs to be found and repaired with epoxy and coolant refilled
Oct 28, 2009 | Samsung Refrigerators
THe freezer is working fine, but the fridge is not cooling very well MODEL HTS22GBPBRWW
samsung RS2555SW the freezer temperature is 58 tryied to changed to -4 it goes back to 58
Aug 13, 2009 | Hotpoint Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
