Question about HP DeskJet 3650 InkJet Printer
Why won't a brand new hp 3650 printer pick up the paper?
  • tommya300
    tommya300 May 11, 2010
    never did ? did you remove all the packing that it was wraped up itn lke the tape amd followed all they have instructed you to do. Then check if the paper load in to many try 1/4 inch or less stack for start 1 sheet is all you really need. fresh paper no damp stuff it will never work has to be flat and dry, Even the machine need to be in a ward dry place.see if this helps
  • 108 Answers
The feed rollers might be slipping. Check to see if you can clean the feed roller. use just a little isopropyl alcohol on a soft cloth. also use regular 20lb. paper.
Posted on Jul 30, 2009
Is there anyway to enable the 3650 printer to print on Kodak Premium Photo Paper. Paper weight 66 lb. thickness 8.5 mil. Printer jams each time I try to print
Hi Jerry
This is a budjet printer and ity's not really made for anything ohter than standard weight 'copier' typer paper.
66 lb. paper is equivalent to 240G paper here and that doesn't go though machines easily unless the paper feed is from the back. HP printers traditionally roll the paper around a roller and feed it back on itself. This paper (it's almost card) is too thick to go around the roller.
If you want to print a lot of this paper you are going to have to buy a new printer. I would recomment a Canon MP560.
Aug 09, 2010 | HP DeskJet 3650 InkJet Printer
The paper will not feed
wipe the roller using water to pick up paper
Feb 02, 2010 | HP DeskJet 3650 InkJet Printer
How to cancel a print order
use the control panel on your computer, pick the printers, double click on your printer and it should list documents currently in Q. Highlight the print jub and pick the documnent ta b at the top left of the window and pick cancel.
Nov 03, 2009 | HP DeskJet 3650 InkJet Printer
Paper jam error but without any paper jammed. btw printer is hp 3650
Do Page Alignment & it will fix you problem.
Check Is there any peace of paper remained in printer. Clean Page Loader.
Thanks.
Oct 14, 2009 | HP DeskJet 3650 InkJet Printer
Hp deskjet 3650
Hallo chattykatty4,
Here's the driver software you need to download and install for the your computer to recognise your printer:
http://drivers.softpedia.com/get/PRINTER/HP/Hp-deskjet-3650-color-inkjet-printer-9440.shtml
Season's greetings :)
Chris (ziraffa)
Dec 24, 2008 | HP DeskJet 3650 InkJet Printer
Paper jam?
There is most likely some paper jammed inside the printer. You just have to carefully look everywhere you can see to see if there might be a little bit of paper stuck somewhere.
Often blowing gently (and dryly) into the printer will dislodge whatever is stuck.
Jan 13, 2008 | HP DeskJet 3650 InkJet Printer
Printer jams when using Kodak Picture Paper
Check the HP support pages, but as HP inkjets turn the paper over internally it means their weight limit is likely lower than others. Also check you have loaded paper face down so it is glossy side UP as it turns over for printing. Their site quotes a max weight of 200GSM for thick stock http://h10025.www1.hp.com/ewfrf/wc/docum... Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
May 05, 2007 | HP DeskJet 3650 InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
336 people viewed this question
Seeker5211
Seeker5211
