Question about Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case
I have a Nexstar 3 external 3.5 hard drive and it is shown as the F drive under my computer. Now the F drive doesn't show up and when I turn my nexstar on and off it just sounds like a record skipping inside, like it's failing to start up?
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • joannelane Dec 30, 2010
    Hi there, thanks very helpful but right clicking on the drive didn't do anything. It said did I want to utilize so I said yes. But then it still doesn't show up and the only other option is to "partition" which sounds like it might erase my other c drive which I don't want. Can you help please?
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Files disappearing on external hard-drive (nexstar.3)
In this case you should use data recovery software to try recovering the files and data, provided those lost data are not fully overwrtten.
Be careful: Before your files are recovered, do not attempt to save more files to the external in case the original files are overwritten.
Feb 21, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Sep 02, 2017 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar
Its normal, and is the signal showing the drive powering/spinning up and down. The drive spins at 7200 rpms, when you power it up or down, its switches onto the speed that best suits  what it's intended to do.
Oct 14, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec NexStar-3 External 3.5inch SATA&USB2.0 Hard Drive Enclosure (Black) (NEWITEM58149860) Drive Case Logo
1,156 people viewed this question
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
