Question about Dell Computers & Internet
The jack for the power cord has fallen inside dell inspiron b 130
    Problem Solver:
  • 13 Answers
********** REMOVE ALL SOURCES OF POWER**********turn off all power wait about 30 mins remove cover and look for the jack put it back in place and replace cover.....
Posted on Jul 30, 2009
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 22, 2012 | Dell Inspiron 1525 Notebook
Dell inspiron elec cord isn't firm so power turns off
Maybe it's the DC Jack that the power cord plugs into. If the jack is loose then you will experience the issue you are having.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 18, 2012 | Dell Inspiron 1525 Notebook
Hi i have the 4 battry (used in the dell inspiron 5030) there are all new battery but there are not detect with tha not books? please help me how i can solve this problem? best regards saeed birjandi
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jul 07, 2011 | Dell Inspiron M5030 Laptop
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
Hello.
Hope this helps.
May 26, 2011 | Dell Inspiron 5160 Notebook
Hi my dell inspiron 1520 not starting when power button is switched on..the power light blinks and goes off..and the system doesnt start. I had shown the laptop ito dell service center and they have...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
But, if you paid for the Dell service, Dell needs to fix the problem. Sounds like they replaced the motherboard with another faulty one.
Hope this helps.
Feb 12, 2011 | Dell Inspiron 1520 Motherboard
Dell inspiron 9400 not booting up. no light in display. num keys and caps locks flashing
Hello.
Hope this helps.
Jan 28, 2011 | Dell Inspiron 9400 Notebook
Power jack replacement Dell Inspiron 6400
When you press the power button, no lights, fans, beeps, anything?
Is the power jack moving around? If not, I would check the charger and cord to make sure power is getting through to the plug that goes into the jack.
Jan 14, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 1525 won't turn on
check the dc power jack connector, open the board. but if under warranty don't open it, bring to warranty..
Jun 05, 2009 | Dell Inspiron 1525 Laptop
Problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
Mar 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Dell inspiron 6000 power cord connection
Hi
I am afraid it is going to be a a bit of work taking the laptop apart, solder the power jack than put back together.
If you are not confident to doing it i suggest you seek help by having a repair shop/centre service it for you. If the laptop is under warranty, you are better of raising a warranty call.
Anyway, you will need some screw drivers; small Flat and a Philips heads. You will also need soldering iron and lead. Finally, a work table will make things easier.
Check Replacing the System Board for help access the system board. Check and solder yo the power jack carefully and reverse the steps to put the laptop together.
Let me know how you get on.
Mike
May 26, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
