Question about Singer 2732 Mechanical Sewing Machine
The needle will not go up and down - even when you turn the wheel. It appears that something has dislodged when looking in the needle housing assembly area.
  • Singer Master
  • 1,388 Answers
Have you released the clutch for bobbin winding ?? Either pull/push or half turn on the inner handwheel.
Posted on Aug 02, 2009
Trying to sew a thick material, it just stopped and now I can't move it up and down . the wheel? doesn't have any effect on the needle in its stopped position. did I burn out the motor?
Sounds like some thing in the drive train to the plunger has broken, if it has a belt drive possibly the belt has broken or become dislodged.
Nov 02, 2017 | Sewing Machines
Janome 6600. Needle came loose &fell down into the bobbin area. Needle did not break off. I took off the plate and manually tried to move a new needle and shaft up/down. needle is hitting something
If you did not get the old needle out, it may be blocking something. That old needle must be removed before you attempt to any further sewing. Try removing the bobbin case from the machine and looking in there to see if you can locate and remove the old needle. Sometimes, I've had to turn the machine sideways or upside down and shake it to dislodge the needle.
Open the bobbin area and hand rotate the handwheel while watching the needle action. If it is hitting, you should see it. If that is the case, the machine may be out of time and need service.
Jul 11, 2017 | Janome Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Wheel on right side that controls the needle up and down is very tight...
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
Turned my Husqvarna Viking 600E sewing machine upside down to dislodge broken needle that fell inside, now it won't turn on. Help
if you still haven't got the machine to turn on, you may have to have it checked, if it has a computer in it, it could have done something to the computer..
May 20, 2015 | Husqvarna Sewing Machines
My 503 white superlock has been in storage for a few years, I cleaned and oiled it but it seizes up at about 3/4 turn of wheel then stalls. any ideas?
Sounds like something is jamming inside. Maybe something has come loose in storage. I would turn it upside down to see if anything comes out, even an old broken needle can do damage if left inside.
Oct 01, 2014 | Sewing Machines
How do you remove the housing? Something stuck in there.
I would try removing the foot plate and feed dogs first. that is usually where a knot of thread can disable the machine.
Aug 07, 2014 | Euro-Pro Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
How do I fix thumping/clunking sound?
make sure your needle is facing the right way, some needles if you look at the front and back you will see a groove side and a flat side sometimes it is hard to tell the difference depending on needle style.. hold it up to light and look at it from the side the difference will be slight but you will see a difference groove should face the back or if your presser foot is out of wack (lol so technical terminology) it could cause needle breaks and noise you can detect damage to the presser foot if this is happening.... only other thing i can suggest is to make sure bobbin is securely snapped into the housing if not it can cause problems with the needle picking up the bobbin
Apr 08, 2010 | Brother CS6000i Computerized Sewing...
The needle slows down and I have trouble turning
Under the needle there is a door you of to open. Between the round wheel and the housing, thread has congested. Take that away and probably that was the problem.
Jan 20, 2010 | Sewing Machines
Needle won't move; something stuck/dislodged
Can you remove the bobbin? Sometimes when thread gets bunched up under the lower plate it will force the bobbin out of position. Try taking it out and cleaning any loose thread and lint from the area. Put a couple of drops of oil on the outside of the bobbin case and re-insert it. Make sure you lower the needle and pull the bobbin thread through to the top and back behind the needle before beginning to sew again.
Hope this works!
Zelma
Jan 18, 2008 | Brother XL-2230 Mechanical Sewing Machine
Singer 2732 Mechanical Sewing Machine Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
