Question about Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P...
My whirlpool gold ice maker produces ice just fine but the dispenser works good some days other days it takes forever to get enough ice out to fill a cup.
  • Whirlpool Master
  • 1,606 Answers
Remove the bottom kick plate , and make sure the bottom coils are clean of dust , lint , pet hair , etc .
Posted on Sep 09, 2009
My ice maker quit, was replaced with a new one, it filled and dumped one time, filled again, didn't dump, was thawed out then didn't fill at all. Water still dispenses from the door just fine.
If the unit is new return it for another one - if there is water in the tray and it is not dumping, either the unit is not working properly or the internal freezer temperature is not going down low enough for the unit to work. Has to go down to at least 10 degrees for the tray thermostat to start the ice dump/making cycle.
Nov 28, 2013 | Whirlpool Refrigerators
Ice maker is not producing ice. Water dispenser is working fine. On Whirlpool Gold Model #GS6SHAXLS03
If the ice maker is not refilling with water after its last harvest that points to the=> W10408179 Water Inlet Valve. If the ice maker just sits there with ice and does not empty into the ice bucket we will need to test the 4389102 Ice Level Control
Instructions on how to test can be found HERE If you have something else happening here please let me know, Sea Breeze
If the ice maker is not refilling with water the side of the water control valve that fills the ice maker is defective and you will still get water from the dispenser. The parts I listeed above are for your GS6SHAXLS03 refrigerator.
Oct 15, 2013 | Whirlpool GS6SHAXLS Side by Side...
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whirlpool White Conquest Side-By-Side Refrigerator GS6SHAXLQ03, manufactured March 2003. The ice maker creates ice and fills the "holding bin" on the interior of the door. However,...
The ice will melt during the defrost cycle. Make sure your freezer is cold enough, at least -5, preferably -10. also, if your freezer is not full of food, put some milk jugs full of water in there to take up space. This will keep the temp colder when the compressor shuts off for the defrost cycle. if there is too much empty space, there is not enough mass to stabilize the temperature and keep it cold.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
Open Questions:
See all Whirlpool Gold Series GI15NDXT 15" Automatic Ice Questions
Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P... Logo
188 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
