Question about Toshiba Satellite Pro S300M-S2403 Laptop
My Toshiba SP2100 won't turn on
Hi. My Toshiba SP2100 won't turn on. It's quite an old laptop, but I haven't had any problems with it before. I've tried taking out the battery and holding down the power button for 20 secs. It works afterwards, but only for a few seconds and then goes off again...Any suggestions would be very welcome!
  • cgcara Aug 02, 2009
    Thanks gerion, I'll keep that URL for future reference...Turns out my AC adaptor had died so I just got a new one and laptop is back in action again.
  • 32 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
24
Posted on Aug 01, 2009
Hello, I have a Toshiba A305-S6857 and will it will not stay on. I've disconnected all hardware and it won't stay on then either. I replaced the motherboard/processor/CPU and that didn't help...
Hi Luke Haag,
This is a common problem we see in the shop. However, you've gone to extreme in troublshooting! My guess is a component is overheating, and since you didn't mention the Ram, I would replace that and see what happens. Also, is the system taking and holding a charge? If the battery is bad, or the power-adaptor isn't delivering electricity to the battery/board, it may eb shutting off simply because there is no more power.
Please check those things and let me know how it turns out.
10base2
Jan 11, 2013 | Computers & Internet
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
My daughters toshiba model PSM43U- won't boot
Hi
There are a lot of reasons,
First of all, try to unplug the battery, hold the power button for 30 seconds,
then plug in the charger.
If the notebook boot, then plugin the battery and try to boot it.
If booted , then N!ce, you've done it.
If not, it seems the battery have problem,
Let's see, try it and tell us your result.
Regards.
Oct 29, 2011 | Toshiba Satellite M45-S165 Notebook
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Hi my toshiba L455-S5045 won't power on, I've
This clearly shows that you have a defective motherboard and it needs to be replaced. Try contacting Toshiba support for this, hope this computer is still under warranty.
Jun 30, 2011 | Toshiba Computers & Internet
Toshiba satellite pro sp2100 -> Mod No: ps210E
TOSHIBA
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 15, 2011 | Toshiba Computers & Internet
Instruction manual for toshiba sp2100 model no ps210E-006p9-4D
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. I had to go to a website based in Poland to find this manual for you, took quite some time! To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
http://micromatikal.dlinkddns.com:8000/cust/SP2100.pdf
Oct 15, 2010 | Computers & Internet
Toshiba Satellite Pro S300M-S2403 Laptop Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
