I have a 52 inch rca model#d52w15 im trying to take out the flyback and cant get the red wire on top of it out. now how do i take out the red wire??
  • 476 Answers
After you lift the ribber cover located on top of the hvt you'll see two grooves in the plastic near where the red wire goes in,you'll also see a hard plastic ring that locks into the two grooves i mentioned. find a pair of needle nose pliers thin enough to press on both grooves at the samr time while pulling on the red wire without breaking the plastic ring.
Posted on Jul 30, 2009
Rca 52" 3 light flash not turning on
Check circuit board for bulging at the top capacitors. The board you are looking for is the one with the flyback transformer. This transformer is the one with a thick red wire going to the top of it. Replace all bulging capacitors. Capacitors are the ones that look like little cans. While you are there resolder the bottom solder points on the flyback transformer. This should work, because it worked for me.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv not turn on
you will need to replace the flyback number 259296 and CP150 you can get the parts at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W15 TAKES AWHILE FOR IT TO POWER ON THE GREEN LIGHT FOR
Ck 3 capacitors cp114,120,150, if any of them is puffed up on top replace all 3 2200uf 16v other 2 are 220uf 35v /resolder all pinns on Flyback Transfomer.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA
The flyback is the big black thing on the deflection board. usally has big red wire coming out the top. THe three small rectangular items are special fusable resistor. or fuses
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch hdtv model D52W15
Blue CRT has shorts that causing the set to go into protective shutdown.
May 01, 2008 | RCA D52W15 TV
RCA D52W20
the flyback is the transformer with the RED wire that resembles a spark plug wire you can get one at the following link for under 50 dollars and comes with free tech support by way of on line instant messageing. They sell that flyback which is a part prone to failure. Its the only RCA flyback that they stock. Heres the link.
Apr 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52" projection tv 3 flashing lights, then powers off
If you see the flyback. That has a large red wire resembling a sparkplug wire. That wire goes into the splitter. There will be 3 more red wires coming from the splitter going to the CRTs. Just take the one wire that goes from the flyback and place that in the glass jar. Now some models have the splitter built into the flyback if thats your vase scenario you will need to replace the flyback. No way to test that properly unless you have a ringer to test it with. let me know how you make out.
Mar 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
