My Tasco digital trail cam model 119223C wont power on. It always says OFF when I push the power button. I have replaced the SD card and fresh batteries with no luck. Can anyone help me out?
If your Tasco digital trail camera is not powering on and only displays "OFF" when you press the power button, despite replacing the batteries and SD card, there are a few additional troubleshooting steps you can take:
1. **Check Battery Orientation:**
Ensure that the batteries are inserted correctly with the correct polarity. The camera won't power on if the batteries are inserted improperly.
2. **Battery Contacts and Compartment:**
Inspect the battery compartment for any signs of corrosion or damage. Clean the battery contacts and the inside of the compartment using a clean, dry cloth or a cotton swab.
3. **Test with Known Good Batteries:**
Sometimes, even new batteries can be defective. Try using a different set of known good batteries to eliminate the possibility of faulty power sources.
4. **External Power Source:**
Some trail cameras can also be powered using an external power source or a compatible external battery pack. Check if your model supports this option and try using an external power source.
5. **Reset to Default Settings:**
Look for a reset button or procedure in the camera's manual. Resetting the camera to its default settings might help if there's a software issue causing the problem.
6. **Check for Firmware Updates:**
Check the manufacturer's website for any available firmware updates for your specific camera model. Updating the firmware can sometimes resolve software-related issues.
7. **Inspect for Physical Damage:**
Carefully inspect the camera for any signs of physical damage or water ingress. Ensure that all compartments, seals, and openings are properly closed and sealed.
8. **Contact Tasco Support:**
If none of the above steps resolves the issue, it's advisable to contact Tasco customer support or consult the camera's manual for specific troubleshooting steps. They may be able to provide additional guidance or recommend further actions.
If your trail camera is still under warranty, consider reaching out to Tasco's customer support for assistance. If not, and the issue persists, you might need to consult with a professional camera repair service for a more in-depth diagnosis and potential repairs.
