Question about Sewing Machines
The top thread breaks when machine quilting with the feed dogs down.
  • 19 Answers
Since you're quilting you're probably stitching a thicker amount of cloth than "normal" try reducing the tension on the top thread. Read the manual, it will explain how to do this.
Posted on Jul 30, 2009
My Pfaff hobby 1200 keeps breaking the thread while free motion quilting.
I'd try switching the needle type & size and then a different brand of thread.
5 things you need to know about thread when free motion quilting
Machine Quilting Thread Shreds Then Breaks
Thread Top Thread Breaking Shredding while free motion quilting NEED HELP
Thread breaking or fraying when free motion stippling
Oh, yeh, one more thing I just thought of: Rethread the top thread and make sure the thread is not hanging up on the spool, spool pin, or wrapped around a thread guide. When my thread breaks after 3-4 inches, it's usually because something is stopping the top thread.
Jan 14, 2018 | PfaFF Sewing Machines
How do I free motion on my excel 18w
Free motion is similar on most machines.
Install a brand new sharp needle (embroidery, top stitch, microtex, or universal) of the size that is compatible with the thread weight and fabric.
Drop the feed dogs. If you machine doesn't have the capability, there should be a feed dog cover in your accessory kit that needs to be covered,. This prevents the feed dogs from interfering with your manual maneuvering of the fabric.
Install a darning foot or free motion foot.
Test your stitch and adjust the tension so the threads meet in the middle of the fabric.
Then, it is a matter of practice, practice, practice...
Learn How to Free Motion Quilt Stippling
Free Motion Quilting Tutorial for Beginners Suzy Quilts
https://wpt.org/SewingWithNancy/Video/free-motion-quilting-beginners-part-1
How to Free Motion Quilt on Regular Sewing Machine
lots more web sites available...
Jan 03, 2018 | Sewing Machines
Trying to quilt on my Hinterberg. First the thread kept breaking. Made some tension adjustments, now I am skipping stitches
possible problems
1) too thick for the feed dog to move the fabric forward need; lighter tension
2) are the upper and lower threads the same kind of thread?
3) is the thread feeding properly from above? sometimes the spool can snag the thread causing the tension to jump and skip stitches
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
Brother Innovis 1e isn't stitching properly when the feed dogs are down
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Nov 25, 2013 | Brother Sewing Machines
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
May 02, 2010 | Janome Memory Craft 9000 Computerized...
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Oct 21, 2009 | PfaFF Sewing Machines
The top thread breaks (or comes right out of the
Take a look through this comprehensive list of
TROUBLESHOOTING
symptoms and possible solutions, it may also be useful for further reference in other times of need.
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Sewing Machines
MegaQuilter Tension
Try at least 2 new needles first (HLX5, preferably Schmetz). If same, look for any rough edges on the needle plate and feed dog cover.
Beyond that, this does not sound like you are doing anything wrong. You should take your machine in for adjustment by an authorized technician. You should have about 1/2 to 1 full turn of the upper tension knob between too loose/ugly on back and too tight/breaking on the top.
May 10, 2009 | Husqvarna Viking 1
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
