Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
W010 wifi connection failed
Hi i have similar problem, i tried to find wifi network at my office and it found but when i tried to connect it showed me this weired error...it sucks!!
I tried to add that network manually, when it asked me security option, i selected no security...but its still not working...
Please help me...i have got Pearl Flip 8220....
  • tommya300
    tommya300 May 11, 2010
    did you or someone else setup the wifi router and can you try the cat5 to see if that responds
W010 error
Posted on Dec 08, 2012
    Scholar:
  • 148 Answers
  • delete all preferred networks first
  • then try to connect
  • and tell us exactly the exact error message
Posted on Aug 12, 2009
How do I enable the wireless internet connection in my laptop? brand is fujitsu fmv lifebook#FMV-E8250?
go to control panel, click on internet connection click on establish find the wifi system in use then enter the code for the wifi system and it connects
May 26, 2017 | Fujitsu Computers & Internet
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Mc3100 find the wifi networks but can't enable the connection
Hello
I am working on the assumption that a laptop can correctly connect to the wireless network and only the MC3100 devices cannot connect.
FedEx and UPS had a similar issue as Windows CE wireless NIC's do not natively support higher level wireless encryption settings that modern wireless routers and Access Points can be configured with. This would result in an similar issue that you have described - the device can "see" the network as it is being broadcasted. When the authentication tries to occur, the two devices cannot "agree" and the device fails to connect.
If this is possible in your wireless environment, change the encryption settings on your wireless router or Access Point down from WPA2 or higher down to WEP remove encryption all together (for testing only).
It is very likely the MC3100 will be able to connect to a non-encrypted wireless network and a WEP enabled wireless network.
Once you get the device connected, try increasing the wireless encryption levels on the wireless network and see how high you can go and still have the MC3100 connect.
Hope this helps!
Nov 09, 2013 | Zebra Symbol MC3100 Wireless Mobile...
Cannot connect to wifi with phones
Try this:
On you cellular phone go to the Data Network and turn it off then on. This helps me when I have the same issue. Im using an IPhone.
If you are unsure on how to get to your Network Data reply to this blog and I will try to give you the steps to access your Network Data.
Jul 31, 2012 | Linksys Wireless-G WAP54G 802.11g/b...
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
The wifi will not connect
You have to go through the settings menu and then to wifi. From there you want to make sure the check is green. If it is green there should be a list of wifi networks in the local area.
If it wont turn green: there is likely an issue with the device. You can try updating the rom (see the support tab on the velocity cruz website). This can many times fix issues. If this was done I would try doing it again to make sure there was no glitch and if it still fails contact the seller or velocity.
If there are networks: Try connecting to the one you know (or that you know is safe). You probably need a password to get on. That is something you'll have to find out, it was set with your wifi router/adapter. If you want to try a place that has wifi you can go to starbucks or something similar where you know there is wifi and it is free. This should give you access to a network to troubleshoot that. If you see networks and cannot connect at all there is likely an issue with the device and you should contact the seller or velocity.
If there aren't networks: You need to ensure that there are networks in the general area. Using a laptop that has wifi enabled and an adapter either built in, usb, or card, generally shows networks. If other devices find networks and your cruz doesn't try updating the firmware (cruz website>support tab). If you still cant find networks that other devices can there is likely an issue with the wireless card within the device and you should contact the seller and/or velocity for an exchange.
good luck
Dec 12, 2011 | Velocity Tablets & eReaders
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
When I try to connect via my home wifi network, the error message "No gateway found" appears. I have put in the WEP key.
You would receive this message when you are trying to connect to a wifi network if any of this is the problem;
1. The wifi network you are trying to connect to has a connectivity problem and hence you are having that error message.
2. The wifi is available but has not connectivity to the internet.
Sorry this possibly means that your home wifi network has some problems.
Regards
Aug 16, 2009 | Nokia E71 Smartphone
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
1,076 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
