I have been given a White-westinghouse steam iron as gift (it is not new); it have the large tank that the iron set on. There is no book and I do not know how to operate it. Can you help?
  • 2 more comments
  • 1_7jlc Jul 31, 2009
    There are several numbers on the bottom of the iron box but none specially saying serial number. All the numbers are:WWSR1; 990810 (also on the power cord); E142249
  • 1_7jlc Aug 07, 2009
    The iron in question is not a regular steam iron; I stated it is a Power Pro Steam Station; the iron sets on the water tank; there is no hole in the front of the iron!; there is a large clear tank in the base of the station and a filter of some sort in the tank; I am not willing to try the iron because it may have been a recalled item or I may ruin it in the effort; please do more research. thanks, Barbara Champaign
    Sorry, my computer will not let me paste the manual to Contacts nor will it let me open the manual; help if you can. thanks, barbara
  • 1_7jlc Aug 13, 2009
    I wish I could take a picture of this iron and send it to you; it says "Power Pro Steam Station"; all the numbers on the bottom of the station are: WWSR1; 990818; Steam Station 75MA; E142249. The iron sets on the station which has a transparant water tank in the front. All the info available does not show a White-Westinghouse iron.
    President:
  • 1,723 Answers
The little how in the top is for adding water to make steam. Buy 'distilled' water only, or it will get plugged up with scale. Pour a little water in, not too much, then turn the control dial to the appropriate setting for the type of fabric your using. If you can give me the model number and manufacturer make of the iron I can send you the manual if you want?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 13, 2009
  • 11,896 Answers
Copy and Paste this link into your address bar to download your manual:
http://laundry.manualsonline.com/manuals/mfg/westinghouse/westinghouse_iron_product_list.html
Posted on Aug 07, 2009
    President:
  • 1,462 Answers
You can get the maual for your ron using the link specified below..
Since you dint specify the model, and there are three model available.I have uploaded all the 3 models manual..
Just visit the link mentioned below and click GET THIS MANUAL, to download the manual
IRON WST5000ZE
http://laundry.manualsonline.com/manuals/mfg/westinghouse/wst5000ze.html
WST5019MEX
http://laundry.manualsonline.com/manuals/mfg/westinghouse/wst5019mex.html
WST5017
http://laundry.manualsonline.com/manuals/mfg/westinghouse/wst5017.html
WST5001ZE
http://laundry.manualsonline.com/manuals/mfg/westinghouse/wst5001ze.html
Enjoy! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Aug 08, 2009
    Genius:
  • 1,043 Answers
The basic operation of the iron shouldn't be too hard. Most of the steam irons have the filling opening at the front of the iron. On the side of the tank should be markings to let you know how much water to pour in. If possible you should use distilled water especially if your tap water has a lot of minerals. They can clog up and ruin the iron's steam vents. If you do use tap water make sure you empty out any water left in the tank.
There should also be a control slider that would show you where to set it depending on the type of material. Some materials need a lot more heat because the are thicker or more dense. Permanent Press items do no need as much heat.
Hopefully this information will help you to get the most out of your iron.
Posted on Aug 04, 2009
  • 453 Answers
Can I have the exact model number for the iron box?
Posted on Jul 30, 2009
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
I HAVE A WHITE WESTINGHOUSE POWER PRO STEAM STATION THE IRON HEATS UP BUT WILL NOT PRODUCE STEAM
Same problem. Threw it out. It was like that from the day I bought it - NEW.
Oct 14, 2011 | Irons
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
No Steam
Your iron will only steam when it has reached the desired tempeture. When the yellow/orange light comes on and the dial has been set for cotton or linen it should steam, when you lower the top and push the steam lever
Nov 01, 2007 | Singer CSP1 Iron
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
