My Ruud "Achiever" compressor makes a loud clunk sound when it shuts off
  • 614 Answers
You most likely have broken spring inside.Russ This wont hurt anything. Russ
Posted on Jul 31, 2009
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Freezer noise
clunk comes from the compressor - possibly dismounted or sometimes assembly inside hits casing on switch off or switch on. no cure except replace compressor
Jun 19, 2008 | Kenmore Freezers
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
