Question about Toshiba Televison & Video
Hi, i have a toshiba 32av502r when i hook the hdmi cord to any of the 2 inputs i am not getting any sound i have went through te settings but cant figure it out do you have a solution before sending it out for the warrenty? all other inputs and outputs work even the av outs.
  • 92 Answers
I have a toshiba laptop a205 I have the usb adapter to hdmi cable hooked up to the tv I cant get picture or sound
First, you need to check the input setting on the TV (change it to HDMI and which HDMI because some TV have more than one HDMI input).
Second, please check the Output on the laptop (cycle it; laptop only, external monitor only, both of the screens).
Mar 04, 2014 | Computers & Internet
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
I have hooked up my DTV box via HDMI to my Yamaha. I have hooked up my Xbox via HDMI to my Yamaha. I have Hooked up my Yamaha via HDMI to my Toshiba flat screen. I can get video from all but I am not...
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
Nov 20, 2010 | Yamaha HTR-6130 Receiver
I have an HDMI cord hooked to my Bravia it is set on video 6 the cable box is powered on and funtiona and the HDMI cord is good. I am getting no sound and no picture is there any way to test the HDMI port...
if you have video im assuming you do if you can see its on video 6 look at hdmi port and make shure its video 6 if your not shure leave it hooked up the way you have it turn on cable box and go thru all inputs example put it on video 1 wait for 60 seconds if nothing happens go to video 2 and so on and so on be shure to wait at least 60 seconds before you change to another input good luck
Feb 03, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
How to I permanently set the picture size on my toshiba 32AV502R? I choose pic size, but when I shut the tv or go to a different input.. it resets when I come back.
Unplug,replug about an hour later should be back to normal reset to factory setting.It should work now because not in custom setting anymore.
Dec 10, 2009 | Toshiba 32AV502R LCD TV
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
534 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
