Question about Samsung SyncMaster 950 P (Ivory) 19" CRT Monitor
Screen totally dark with a brigh vertical line at the center
Monitor was working OK until turned off for the night. Problem appeared next time it was on, and can't be corrected with on-off, or using horizontal-vertical controls. Is it fixable?
  • 180 Answers
Re: screen totally dark with a brigh vertical line at the...
Check the electrolytic capacitor in the vertical amplifier circuit.
Posted on Apr 09, 2008
0 characters
3 Points
A thin vertical line(Green) has appeared on the screen
Hi peterbb24 - Welcome to FixYa!
It seems like you're annoyed by this vertical line running across your screen. At first, it may seem nothing and wont bother you much but as an expert (and based in my own experience), I have to give my fair recommendation to test your screen while in BIOS mode and see if the problem continues.
How to go to BIOS?
1. Turn OFF your computer
2. Turn it back on and hit "DEL" key repeatedly until you see a screen like below :
Stay on this screen for several minutes (1 hour recommended) and see if you'll still see that annoying line. If the problem continues, then it's high time to send this monitor to the authorized repair center to get it fixed. Otherwise, the problem could be software-related which requires you to backup important files and re-install your operating system. Please refer to your system's user manual for the appropriate guide in doing operating system re install.
Thank you for using FixYa.
Feb 27, 2011 | Xerox XA3-15B (Black) 15" Monitor
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
May 19, 2010 | Westinghouse L1975NW Monitor
A dark blue ink splodge has appeared on my screen! It started at the very top of the computer and has run down the screen. can this be fixed?
Usually we can see these type of spots, if we place any magnetic field next to a CRT monitor. Try removing if any speakers or its power adapters or any radiating devices near to the monitor. It will get ok after a while.
If still the problem persists contact a service center.
Please come back and rate my solution if this turns helpful for you or also if you need more clarification. Thnx
Apr 04, 2010 | IBM 11P836402 for ThinkPad R40 Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
There is a vertical thin line going up the center of the screen. It's appears when I turn the monitor on and the only time it disappears is when the screen is white.
change your vga setting and monitor setting by right clicking on desktop try using your monitor different htz setting in advance tab and monitor setting
Jul 22, 2009 | HP L1702 17" LCD Monitor
Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
May 29, 2009 | HP w2207 Monitor
AOC spectrum 7 Glr ?
Initially, I would suggest that you do a full reset, that is unplug the monitor from the mains and the PC for a couple of hours (preferably overnight). The idea is that the monitor will reset itself to default factory settings. Thereafter try again.
Should problem persist, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Apr 12, 2008 | AOC LM729 17" LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Screen goes black with bright white horizontal line
This problem of loss of vertical deflection with the line offset from center suggests a cold solder connection in the vertical sweep circuit or in the power supply to the vertical sweep circuit. Most service shops should be able to fix.
Jun 30, 2006 | LaCie Electron 19" CRT Monitor
Samsung SyncMaster 950 P (Ivory) 19" CRT Monitor Logo
169 people viewed this question
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
