Question about Casio Cameras
Whe; I try to open my Casio moment setter an error message come up
How to solve error 628 in idea net setter. please give me an advice? i installed my idea net setter in my laptop, but when i click to connect, i've got a message ERROR:628, redial or close option are...
i also faced this problem error 628 code error again and again.. the solution explained here is also very helpful.. i fixed this problem by visiting this http://www.error628.com .. someone might get help from this site also.. thanks for sharing information about error 628..
Jul 05, 2011 | NetGear WGR614 Wireless Router
What is the error 619 in idea net setter how to solve please tell me
Jan 31, 2011 | Computers & Internet
Casio Exslim EX-Z33: Lens Error Message; Lens stuck
The camera might not of had been dropped or abused at that moment, but it sounds like one of your ribbons is not full connected to its port due to a previous unnoticeable drop or mishandling. In other words, if you are savvy enough to open the camera, remove the ribbons (2 of them, found on the front side of the camera coming from the lens) and re-insert them into their ports. I have only needed to do this once on this particular camera, but at least 30 times on the Exilim line of Casio cameras. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/pedro_4520403b21ed459a
Jul 18, 2010 | Casio Cameras
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Card error
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual:
http://support.casio.com/pdf/001/EXZ60_e.pdf
Apr 28, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hi I have a sony cyber shot dsc t20 and I get an error message flash settings cannot be changed whe I try and select another flash setting?
I had the same problem, and i tryed everything, even opening
the camera and see if any visible damage on any part (nothing), so
when i try initializing again ( menu>setup>option #1), right after the
"OK" over reseated date, i went to the Flash Button, and turn it off
and at least the annoying flashing error is not there - that means it is
software error, because all flash functions work till it detects that
has ans error wile charging/loading the flash. Hope it helps.
TENFERRE
Aug 25, 2008 | Sony Cameras
Cash register ce -2400
From: http://www.casio.com/support/content/D799D5A7-9C01-40E0-8D11-071A11F4A9A9 , error #11 means the register thinks the drawer is still open. Try opening and reclosing the drawer a few times.
Hope this helps.
Jan 21, 2008 | Computers & Internet
IP4300 print error message
Try holding the "resume" button (triangle in circle) for about 10 seconds for each cartridge.
If that doesn't work, go to a refill shop and ask if they have a re-setter for your cartridges. Most shops do.
The re-setter gives new serial numbers to the cartridges, so the printer thinks you have put in new ones. Or you can buy one.
In 99%, when the printer tells you that one of the cartridges is empty, it's actually not. The chip is the one that tells the printer when to stop printing. If you bypass the chip, you can continue printing.
Hope that helps!
Sep 12, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Cameras Logo
67 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
