Question about HP OfficeJet 7310 All-In-One InkJet Printer
Carriage jam Carriage is stuck all the way to the left and I cannot get it to move. I have tried every solution possible aside from taking it completely apart.
  • tommya300
    tommya300 May 11, 2010
    You are talking about the scanner does not slide? Does it jog when turned on? If it jogs and then shuts off need more details
  • 4 Answers
There might be non functional part on that carriage. you might as well get that spare part from the manufacturer or if still under warranty return it and let them replace it for you.
Posted on Sep 19, 2009
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Carriage Jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
Printer carriage stall/stuck
  1. follow the steps below
  2. Reconnect the power cord to the back of the product.
  3. Press the Power button ( ) to turn on the product.
  4. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position
  • With the product turned on, disconnect the power cord from the back of the product.
  • Unplug the power cord from the power source or electrical outlet.
  • Check for any paper or objects that might be stopping the carriage. CAUTION: If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams can occur.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove any loose paper or obstructions found.
  • Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  • Close the carriage access door.
  • Reconnect the power cord to the product and to the power source.
  • Reconnect the USB cable to the product.
  • Load plain paper in the tray.
  • Dec 19, 2009 | HP Office Equipment & Supplies
    Won't print. Message says "carriage jam. Open door and clear carriage jam." There is no jammed paper or anything visible. Put door back on, still won't print. have turned on and off, and reinserted paper....
    It is giving carriage jam not a paper jam the carriage is the part which carries cartridges on it. It seems your carriage is jam and can't move left and right so open the door and try to move your carriage with the help of rubber roller which moves your printer. Also clean the steel road on which the carriage moves just check at the corner of cartridge carriage if any paper bit is stuck or excessive paper dust has jammed it. If this does not solves your problem kindly comment back.
    Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
    Encoder strip for HP 2175 xi
    Here's the solution for fixing a carriage jam on your PSC 2315xi printer. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042632&cc=us&lc=en&dlc=en&product=90812 But, you said the encoder strip came off. I always understood that if the encoder strip came off, the printer was dead. I've never tried to take the encoder strip off and put it back on again to see what happens. The encoder strip is what tells the carriage where it is. Without the encoder strip, the carriage doesn't know where to go.
    Jun 09, 2009 | HP Office Equipment & Supplies
    HP 1610 Carriage Jam
    Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
    Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
    Carriage jam on hp photosmart printer
    The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
    Solution
    The print carriage is the device which contains the print head and moves left to right during printing.
    Figure 1: Carriage Assembly
    To resolve this issue, follow the steps below in the order presented.
    Step one: Print a Self Test
    Follow the steps below:
    1. Press the Setup button.
    2. Select Print Report and press OK .
    3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
    Step two: Clear the paper path
    Follow the steps below to clear the printer of any jammed paper and reset the printer.
    1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
    NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
    2. Open the top access door.
    Figure 2: Opening the top access door
    3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
    Figure 3: Paper jammed on the left side
    Figure 4: Top view of paper jammed on the left side
    Figure 5: Paper jammed on the right side
    Figure 6: Top view of paper jammed on the right side
    NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
    If the carriage is stuck on the right side:
    a. Check for any paper or object that may be restricting the carriage.
    b. Move carriage all the way to the left side.
    c. Check the paper path all the way to the right side and remove any paper still in the printer.
    If the carriage is stuck on the left side:
    d. Check for any paper or object that may be restricting the carriage.
    e. Move carriage all the way to the right side.
    f. Check the paper path all the way to the left side and remove any paper still in the printer.
    If the carriage is stuck in the middle:
    g. Check for any paper or object that may be restricting the carriage.
    h. Move carriage all the way to the left side.
    i. Check the paper path all the way to the right side and remove any paper still in the printer.
    j. Move carriage all the way to the right side.
    k. Check the paper path all the way to the left side and remove any paper still in the printer.
    4. Remove the rear access door or duplexer (if installed) from the back of the printer.
    5. Check for and remove any paper still in the printer.
    6. Replace the rear access door, and close the top access door.
    7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
    NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
    8. If the Power light is on steady, print a self-test page as done in Step one.
    If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
    Step three: Plug the printer directly into a wall outlet
    Verify that the printer is properly connected to a suitable power source by following the instructions below.
    1. Verify that the computer and the printer have a three-prong power plug.
    2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
    3. Try the print job again to see if this step resolved the issue.
    NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
    4. If this did not resolve the issue, proceed to the next step.
    Step four: Service the product
    If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
    Jan 05, 2009 | HP Office Equipment & Supplies
    Carriage cradle stuck on right side!
    Carriage system is broken. Uneconomical to repair. Sorry
    Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
    Epson 1280 ink carriage making noise and not printing
    hello there. try re-seating the cartridge. Take it out, then put it back in.
    Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    62 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
