Question about Cell Phones
Why won't the G'zOne Boulder disconnect when closed after the call? We have to hit the 'end call' button to get it to disconnect.
My gas forced water furnace has a zone stuck in closed position
EITHER ZONE VALVE RELAY HAS A BAD RELAY CUBE OR YOUR ZONE VALVE POWERHEAD IS BAD .YOU CAN GET JUST A REPLACEMENT POWERHEAD ASSEMBLY OR EVEN JUST A REPLACEMENT ZONE VALVE MOTOR . CHECK WITH A METER AND SEE IF YOU HAVE 24 VOLTS COMING OFF END SWITCH OF ZONE VALVE AND ALSO MAKE SURE YOU ARE GETTING 24 VOLTS TR AND TH/TR .
Jan 07, 2014 | YouTube Videos
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I lost the instructions for the talking Reizen atomic clock and both of them are now an hour off. How do I reset the time?
You need to change the 'Zone' settings on both; the signal from Boulder, CO can't tell where you are, you have to make the correction locally and then they will track the signal accurately as long as they can receive it.
Nov 27, 2011 | Reizen Atomic Talking Clock
The charger port on my g zone boulder came out
you can get a dock to charge it on..u will need your wall charger and it plugs into the desktop charger/dock/cradle or whatever u wanna call it. Then u bypass the need for a port. Bad thing is u cant use the car charger easily without taking the dock with u in the car/but can be done! I am looking for replacement ports for casio phones..if anyone knows where u can buy them?
Dec 12, 2010 | Casio G'zOne Boulder Cell Phone
I have a model CKA-1000 with the 20 ne problem. Last night I pressed the time zone button like it said in the forum and the correct time popped up. This morning, however, it was back at 20 ne. I again...
It is asking for the time signal.Try moving the clock/radio to another area in the house. The atomic clock will pick up the signal from Boulder, Colorado is on a frequency of 60 kHz. Unfortunately house current 120 volt is also 60 kHz and may be interfering with the signal.
Hope this manual will help you out solving the problem
The CKA1000 series will have same manual.So you can use this manual for reference.
Click here downlaod manual1
Click here download manual2
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 08, 2010 | Emerson CKA1000 Clock Radio
Where is the mute button on the Casio gzone boulder phone?
Once you've dialed your phone number and are connected... press "CLR" until the numbers are erased from the screen... Then you'll notice that the "mute" appears on the lower left of the screen. Just press the Upper Left Key "-" and your muted !
Aug 31, 2010 | Casio G''zOne Type S Cellular Phone
Time and outdoor temp not functioning
You probably need to set the time zone. Hit the set button until it shows the time zone (ie -7 MST), then hit the "+" button until it shows your time zone and the correct time. Continue hitting the set button to cycle through to the end of the settings.
Jun 24, 2010 | SkyScan 86709 Atomic Wall Clock
Broken lcd screen-dropped closed phone on gravel drive and a rock hit the case and broke the lcd screen
Change the screen from the dealer. If your warranty period is not over change the scren with no cost. So infor the dealer.Changing the screen is the only solution.
Jan 22, 2010 | Casio G'zOne Boulder Cell Phone
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
How do you get STRENGTH in pokemon leaf green?
try pokedream.com
or
you can find str in fire red and leaf green, go to safari zone found in fuschia city then find the items. .
items contained in Itemballs in the Safari Zone include the Gold Teeth, Leaf Stone, Protein, TM11 - Sunny Day, TM47 - Steel Wing, and TM32 - Double Team. After finding the two "mission" items listed above, head to the Warden's house (the house with a mailbox next to it) in the eastern part of the city. Give the Warden the Gold Teeth, and he'll give you HM04 - Strength. Teach the new HM to a Pokemon, and move the boulder that's blocking the Itemball. Then pick up the Rare Candy.
the teeth is located neer the end of safari zone. . .
the warden is located at the house neer the Pokemon center . . . the house where their is a little pond. . .
Oct 07, 2008 | Nintendo Game Boy Advance SP (Japan...
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
