Sonicview 360 premier says no service or scrambled. i have just received the item today and have no real knowledge of how to update etc. i do not have an ihub, is this necessary?
What sonicview 360 Elite pvr remote code?
0018,0019,0014,0011.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 19, 2014 | Sonicview Universal Remote Control for...
I have a Motorola E815 phone. The screen looks scrambled.
take out the sim card and format or restore to fabrik settings
May 16, 2010 | Motorola Mobility E815
Sonicview 360 Elite Dual w/ Dish500dpPLUS EXC! signal cant watch!
You need to use a sonicview splitter and then go into your settings and select proper ports.If you have 2 wires comming from i duel lnb or 2 stats then you install then in the splitter then one wire into your reciever.then you scan the sats on the ports you have them hooked on to. example echostar110 port 1 also tp setting is 12258 Then echostar119 port 2 also tp setting is 12239 then scan. Scan on autoscan. hope i helped :)
Mar 01, 2009 | SMC EZ Switch SMCGS24 24x1000 Mbps
FTA updates
how do I get to the up dates on the sonicview 360 premier?
Nov 16, 2008 | Fluke Networks (FTAP-8S) Network...
SonicView 8000 HD FTA Satellite reveiver,,Info, Literature,Documents
User Manual:
http://sonicviewusa.com/downloads/manual/SVHD8000_Manual.pdf
Unfortunately, They do not even have a troubleshooting section it that User Manual, I don't know of a service manual, perhaps loading the factory firmware may clear up your issues.
SV-HD8000 Factory Firmware:
http://sonicviewusa.com/downloads/firmware/SVHD8000_Factory_20080108.zip
If that doesn't help, try contacting SonicView Directly at:
support@sonicviewusa.com
or
1-760-884-3171 (Mon-Fri 9AM - 5PM) Not toll-free
Nov 21, 2007 | Televison & Video
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Satellite receiver not respond
Search internet for JTagging sonicview receiver. You will need special equipment.
Sep 02, 2007 | Audio Players & Recorders
Televison & Video Logo
476 people viewed this question
Top Televison & Video Experts
