Question about Garden
Problem inserting a refil spool for grass trinner
Instructions required for inserting refil spool for black and decker garden trimmer GL540.
Please advise.
  • 313 Answers
SOURCE: Black & Decker CST1000 Grass Hog Grass Trimmer
common problem battery.
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
RonPark
  • 855 Answers
SOURCE: Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Posted on Sep 12, 2009
tomgswan
  • 30 Answers
SOURCE: Black and Decker electric trimmer (grass hog)
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Posted on Jul 02, 2011
Why won't the spool on my B&D weedwacker rotate?
Is it on the right way? Does it face the correct way? Is it clogged with solid grass?
Jul 28, 2014 | Black & Decker Black and Decker & Grass...
How to respool the line on grasshog electric grass trimmer
The empty spool can be refilled with 30' of size .065" nylon line. Make sure you run the line in the direction of the arrow embossed on the spool.
Sep 06, 2010 | Black & Decker 14" Grass Hog Xp...
Would like to know how to refill the trimmer line
Hello, There Shoeld Be A Screw On The Bottom Of The Trimmer When You Turn It Upsind Down, Turn The Screw Counter Clockwise And The Refill Spool Should Come Out Into Your Hand,,
Hope I Was Able to Answer Your Question,
Galway John,,
Jul 23, 2010 | Black & Decker 14" Grass Hog Xp...
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
I can't figure out how to replace my spool
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Mar 14, 2010 | Black & Decker 14" Grass Hog Xp...
Refilling string
Wind in the direction of the arrow on the spool and be careful t seat the spool over the rachet fully.
Feb 18, 2010 | Black & Decker 14" Grass Hog Xp...
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
How do i refill spool
how do i undo spool on black and decker auto strimmer d825
Jun 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
