Question about Magellan MAESTRO 3100 98083401 GPS Device
Mine isnt telling me where to turn at all
Mine isnt telling me where to turn at al. You can only see map but it's not telling me my direction
    President:
  • 1,111 Answers
Make sure the gps in not muted. check the mute on and the sound turned up on the map screen and also check the sound in the options/system/ sound, if they are both ok and the try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already. READ UPDATE INFO BEFORE UPDATING,VERY IMPORTANT
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB takes atleast 30 - 60 minutes depending on your system.
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Posted on Aug 06, 2009
Hard starting, misfire & cut out when revved with MAP sensor connected
Hi Bernie, Im AL the owner of Big As Auto Repair
Bernie, this is hard to say without diagnosis, but I can tell you that 99% of the time when you unplug the MAP Sensor and it runs better, then its usually the MAP Sensor. If it should turn out that a new MAP doesn't fix it, then check for broken or frayed wires and check the connector for damage. Hope this helps and please visit my auto-repair website and check out my satisfied customer testimonials.
Jul 03, 2015 | Cars & Trucks
I have mapsource loaded but while all works I cannot see any roads on the maps.Is there a special setting I have to make ?
Get your self a maual for that Garmin,,,If the answer isnt covered there,,,,,Google the same question and end up on a Garmin forum where others are talking about the same problem,,,Als see if Garmin has a toll free number for trouble shooting your unit.
Mar 11, 2011 | Garmin GPSMAP 276C GPS Receiver
If my street goes directly to main street but my map sends me the long way to that main stree, how do I correct it.
i don't think you can. just go the way you normally go and the tom tom will recalculate the route and you shall be on your way.
Sep 05, 2009 | Tomtom One XL GPS Receiver
Magellan 3200 freeze
there is a little square at the top right corner of the screen. when you first turn it on, press that square to see the satelites it has locked on to, once a few of those turn green (meaning you are locked on by sattelites) see if the map starts workign again. Mine did the same thing and i thought is was broken, but depending on where you are, it can take up to 10 minutes for the map to start working (as it need that astelites to tell it where it is and what is around it) get it? so just try waiting before you put in a destination.
Aug 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Navman 1CN 330
i have just bought second hand navman icn310 need manual turns on and keeps saying waiting for gps ?
Mar 26, 2009 | Navman iCN 330 GPS Receiver
Cant get the two maps to align together =(
That totally baffled me! You need to open the map on one screen and the tablet on the other. Close your DS (I mean actually close your system, I'm serious) then reopen it. That had be stumped for a long time.
Jan 01, 2009 | Nintendo DS Lite Console
TomTom gives incorrect location
two things may have occurred one the north american map has been deleted or guam has been set as the active map if you go into the settings you can change active map back to North america
Dec 27, 2008 | Tomtom One XL GPS Receiver
Registeration process
Al right what you want to do is go to a T-mobile store and regester your device...
But then the only way to do that is getting the sidekick plain with them and when there will be a G instead of the phone icon...
When you turn your phone off then back you will be able to put a username and password on it...
Sep 27, 2008 | Sharp Sidekick LX Smartphone
I bought a Tomton One at the end of December 2007, and the last four months I been having problems with the GPS. It shows me the wrong direction. Sometimes it tell me to get off too early, when I'm the...
There isnt much you can do about it, except:
- Make sure you allways have latest firmware
- Make sure to regulary update via Mapshare
- Make sure to report map errors via Mapshare
- Buy new maps...
Apr 14, 2008 | GPS
Map upgrade
I would like to order new maps for mine GPRS-ICN 330. I am interested bought new maps from the countries like:Holland,Spain, France, Germany, Belgian. I need to upgrade mine GPRS navigation (new maps).
And tell me it's possible to have them in Polish language?
Tell me where I can bought them because when I looking in yours web site I can't find the products what I need.
Thank you for your help in advance.
Is mine contact email:spo8@interia.eu
Sep 24, 2007 | Navman iCN 330 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
99 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
