Question about Gateway Belkin F5D7230-4 802.11g Wireless DSL/Cable Router (NWBLKF5D72304)
I have a Toshiba laptop. Window Vista won't
I have a Toshiba laptop. Window Vista won't connect to a Belkins G wireless router. It's telling me the security code I enter isn't correct, however, it's the same code used by my friend who owns the router. She also has windows vista. What am I doing wrong please?
    Champion:
  • 381 Answers
Nice day, so that you can lock the router is, if you want to remove the lock will please reset it, so this little hole in the side and see it you press the 2 to 3 minutes and then restart your the units from mounting the router, good luck and hope this will help you
Posted on Jul 30, 2009
Laptop won't connect to router
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default adminpassword.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2012 | D-Link (R) DIR632 WirelessN 8Port Router
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
Just bought new laptop with window 7 i alreadu have a desketop ant two laptop using window vista on network the new compuuter won t connect
first be sure to check that your wi-fi in on on your laptop. the next step is to reset your router, if that does not work, reset your modem as well.
Mar 11, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connection to Internet at home by Dial up connection
hi,
if your friend is using a dsl connection,im sure he do have a modem from at&t, if you want to share internet connection,you need to purchased a router,here are some brands of the router that is applicable, linksys,netgear,belkins...once you have the router,you will need to contact AT&T technical support to configure the router to the modem so that you will be able to connect either wirelessly or hardwire connection...
thanks
Jan 26, 2010 | Toshiba PCX2500 (pcx2200) Modem
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
2wire312
You may want to double-check if the wireless adapter on your laptop is enabled. If it is enabled, try to view the available wireless networks on your wireless connection and select the name of your wireless network. You may also want to check your wireless router if there is a wireless security enabled. It is important that you know the wireless settings on your wireless router to make sure that the wireless adapater settings on your laptop match the settings on the wireless router.
Jul 02, 2009 | 2wire HomePortal® 1800HW Router...
Problem with downloading router driver/firmware
You don't need software for the router. Is your wireless encrypted or open? Just view avaiable networks with your xp machine and choose your network to connect to. If you do have an encrypted signal use the vista machine and type in the ip address to the router in your browser window. I think belkins router ip is 192.168.2.1 or 192.168.0.1 Hope this helps, let me know
May 25, 2009 | Belkin (F5D8231-4) Wireless Router...
Toshiba laptop running Vista loses connectivity
The problem is not Vista, the problem is the Netgear. I have seen this happen time and time again with both Netgear (primarily) and D-Link (often). That's why I *only* recommend Linksys.
Worst case - go buy one from Walmart (yes, they have 'em). Hook it up and see the difference. If, somehow, the problem persists, take it back, and you've lost nothing. But I'd bet (as they say down here in the South "dollars to doughnuts") that's your problem :)
Hope this helps - remember to rate :)
Oct 02, 2008 | Toshiba Computers & Internet
Trying to connect between cable pc xp edition and new dell vista laptop
the SSID is only the name which your connection is called.
If you have security enabled, you will need to type in the passkey when asked.
First go to internet explorer open it and go to tools>connections tab, then tick 'never dial a connection' and close I. Explorer.
go to control panel>network connections>right click on your wireless connection icon, then go to the TCP/IP line, highlight it, click properties, then select 'Obtain IP address automatically.
Select Ok, then close window, go to internet explorer, then open it up and you may need to click refresh a few times ,but should connect
Aug 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Toshiba laptop wont find router
Right click on the network icon in your task bar or in network connections in control panel and click view wireless networks, then when all the networks show, delete them all and close the window, next, a pop up will say found wireless connections click the pop up icon again and look for your connection in the list and click connect and enter the pass phrase Iif you have security enabled.
Nov 06, 2007 | Toshiba Satellite A105 Notebook
Gateway Belkin F5D7230-4 802.11g Wireless DSL/Cable Router (NWBLKF5D72304) Logo
186 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
