Question about Raymarine GPS
GPS Rc400 Error code 0x4001
When I turn on my GPS i receive this message: ''System Halted Error Code: 0x4001 Please provide the above code to service. Keep pressed 10 seconds the POWER key to restart system''
I have tried to restart but the same message appears again.
Grateful for any advice on this as soon as possible. Thanks, Massimo, Rome,Italy
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This error is due to Corrupted software of your Raymarine GPS RC 400 Device, you'll need to upgrade the software for your device by following the steps, visit this link for detailed instructions--
Raymarine GPS RC 400 software upgrade
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 30, 2009
I've received a mms message and my screen say MMS retrieval failed, how can read this message?
This often has to do with a network error, or your phone its self. The best solutions are as follows.
  1. Turn your phone off and turn it back on and attempt to retrieve the message again.
  2. If that fails, ask the sender to resend the message.
If the above solutions do not work you might need to consult with your wireless provider.
Jun 03, 2011 | Cell Phones
My Panasonic strata nvd905u is going into hardware error at the boot screen
Thank you for allowing me to help you.
I'm providing user manuals for quick reference and WE are going to thoroughly cover/troubleshoot the problem. First, we are going to provide the Manuals. PLEASE do not forget to award your best answer.
- Manual for STRATA NVD905U http://service.us.panasonic.com/OPERMANPDF/CNNVD905U.pdf
Here are the steps We are going to start with
1. Cover all Warning steps pages 2-6
2. If your seeing the below error look at the SOLUTION below
ERROR MESSAGE
Hardware error.
Reboot or press reset
switch.
SOLUTION
There was a malfunction in the amp.
 Press the reset switch on the system.RESET SWITCH IS LOCATED ON THE LOWER RIGHT HAND CORNER OF YOUR SYSTEM
IMPORTANT
Push the switch only when the unit fails to operate
with any buttons. (Stored settings and adjustments
are cleared.) If the unit fails to return to normal,
contact the nearest Panasonic Servicenter and have it
repaired.
Note:
 If the ID code has been already set, you will be asked
to enter the ID code right after the unit is restarted.
 A noise may occur when the reset switch is pressed,
but that does not indicate a malfunction.
ERROR MESSAGE 2
HDD cannot be
read due to low
temperature.
CAUSE
The system could not start up due to abnormal HDD temperature.
HDD cannot be 
SOLUTION
Turn off the power and wait for a while before turning the power back on
TROUBLESHOOTING COMPLETE**************
Please do not forget to AWARD YOUR ACCEPTED RESPONSE
THANK YOU KINDLY
Jan 10, 2011 | Panasonic Strada CN-NVD905U GPS Receiver
My blaupunkt lucca 5.3 Sat Nav says PUK error System block How do I get over this problem please.
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
Jul 21, 2010 | Blaupunkt TravelPilot Lucca 3.5 Edition...
When pulling up geocache map
This is a common problem when you enter geocaches or Waypoints in which you DID NOT SCRUB the html code. Start Deleting Geocaches until you find the bad one and all will return to normal.
Also investigate a program called GSAK and use its stripper before you load the geocaches.
Jun 06, 2010 | Magellan Triton 400 Handheld GPS Receiver
Error code on my RC400 Raymarine GPS 0x4000091 and system is locked any ideas?
It would appear you need to perform a hardware reset.
6.2 Resetting the System
Three types of reset are available for the Chartplotter:
Power-On Reset: When you turn the display unit off, then on again,
the screen reverts to the chart display with all windows cleared.
Hardware Reset: This procedure enacts a power-on reset if the unit
has entered a lock-up condition.
To perform a hardware reset, press and hold the POWER key for 9
seconds.
Hope this helps.
Good Luck!
Apr 12, 2010 | Raymarine RC400 GPS Receiver
Screen with message.. " No detailed maps found that support routi
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Feb 06, 2009 | Garmin nuvi 350 GPS Receiver
Chasis intrded fetal error system halted problem plz hep me
somewhere on the motherboard there should be a switch or jumper to turn it off look for directions either on case somewhere or on motherboard
Jul 30, 2008 | ASUS SiS Chipset P5S-VM Motherboard
Raymarine GPS system HALT ! URGENT PROBLEM
To get back up and running you are going to have to reset the unit. This is from the handbook:
Note: Take care - factory reset clears allWaypoint and Route databases.
➤ To perform a factory reset:
1. Power off the unit.
2. Press and hold CLEARwhilst powering up until <Erase backup procedure>
is displayed.
3. Either press CLEAR to abort Factory Reset and resume normal
Power-Up or press ENTER to continue Factory Reset.
4. Press ENTER again; the unit restarts as for a first time PowerUpwith
all values reset to their original factory settings
When you hit port and have an internet connection, make sure you are running the latest software version, currently listed online as version 1.09. You can download it here:
http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=965
Sep 10, 2007 | Raymarine Raychart 435 GPS Receiver
GPS Logo
374 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
