Question about Sharp Aquos LC-13B4U-S 13 in. EDTV-Ready LCD Television
Where is the reset button on the sharp Aquos - Sharp Aquos LC-13B4U-S 13 in. EDTV-Ready LCD Television
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a sharp Aquos and the input button will not come on black
If you get sound but no picture (black screen), There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 19, 2009
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
How to reset a sharp aquos lc4d62u without a remote
You can use the 'menu' button on the panel (next to power on my model) to bring up the 'Initial Setup' screen. The factory reset option is available from that menu. You'll need to navigate through the menus using the channel up down buttons and the enter button on the front of the TV.
Oct 14, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to reset a sharp aquos?
Hold VOLUME UP and CHANNEL UP buttons in while plugging set into power.
TV comes up in service mode.
Press CHAN + or CHAN - to select an adjustment that you want to change
Press VOL+ or VOL- to adjust
Jul 22, 2014 | Sharp AQUOS 65" 1080P Roku Ready LED 120Hz...
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
Jun 09, 2014 | Sharp LC40D78UN 40 in LCD TV
Lost the remote for my sharp tv. And the control panel is locked. Who do I unlock the control panel with out the remote?
If the problem you are having is that the television's operation lock out for the buttons on the tv has been enabled then the only way to undo that is with the Sharp remote control. The only work around I can think of is to perform an INIT, which is a factory reset. I do not know is Sharp customer service will still walk you through that over the phone because it is a detailed and dangerous (in that it can wipe the memory of your television if done improperly) process. I do not know what type of Sharp you have i.e. aquos or non aquos. 800-BESHARP is the number for non aquos support and 877-332-7867 is the number for aquos support (open 24 hours for aquos support last I checked)---32 inch and over aquos that is.
Aug 20, 2011 | Televison & Video
Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Dec 26, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Is there a reset button on the 27 inch sharp aqua tv?
  • Press "Menu" on the TV's remote control and use the arrow keys to scroll to "Setup."
  • Scroll down to "Reset" and press "Enter" on the remote.
  • Select "Yes" using the arrow and "Enter" buttons at the "Return To The Factory Preset Values" message.
  • Select "Yes" using the arrow and "Enter" buttons at the "Now, TV Will Restart Automatically. OK?" message.
  • Wait while "Now Initializing..." appears on the screen. The TV will power down and turn back on when the reset is complete.
  • Read more: How to Reset a Sharp Aquos ' eHow.com http://www.ehow.com/how_7225301_reset-sharp-aquos.html#ixzz12i633RwM
    Oct 18, 2010 | Sharp Televison & Video
    Sharp Aquos 32 wont turn on
    I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
    They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
    I doubt Sharp's policy alot less now!
    Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
    Sharp Aquos LC-52D64U Won't Turn On
    I have fixed many sharp lcd tv's with a reset. If one appears to have no defects like bad capacitors, fried inverters, broken panel, ect. and the power light is flashing steady or not on at all a reset may help. There is a lot of bad information regarding the procedure though. The correct procedure is to unplug the tv, hold volume down and channel up at the same time and plug it in. Release those buttons then push the power button. Did it start? Great! I have no idea why so many seem to need this. If there truly is a problem this will only work temporarily or even momentarily but many will be fixed for good.
    Apr 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    HDMI connection problem
    Your TV doesn't like your laptop I guess.
    There should be 2 reset buttons behind your TV.
    Press the reset button first.
    If that doesn't work, try the system reset button next.
    If that doesn't work, you'll have to call 1-800-BE-SHARP to help you with the possible software problem with the TV
    Good Luck
    Feb 12, 2009 | Sharp Aquos LC-32D40U Television
    Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
    Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    Sharp Aquos LC-13B4U-S 13 in. EDTV-Ready LCD Television Logo
    1,104 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
