Question about Kenmore Refrigerators
Kenmore refrigerator defrost dranage tube plugged
  • 19 Answers
Empty the fridge, carefully put the fridge on it's side and access the drain from the bottom. There will be a shallow collection tray designed to collect and evaporate the defrosted water, and you may have to remove this with small sheet metal screws.
Once you find the tray you'll see the drain tube. Use a thin but rigid wire to poke into the tube.
An old bicycle brake cable works well.
Also, the plug may be a frozen chunk of ice. Try letting the fridge defrost for a day.
Posted on Jul 30, 2009
Kenmore 10677181791 water dripping into refrigerator from freezer
probably an ice buildup around the drain tube not allowing proper flow thru to the drain. Try defrosting fridge for a while so the entire ice mass defrosts in between fridge and freezer
Feb 09, 2012 | Kenmore Refrigerators
Our kenmore top freezer is leaking (dripping water) inside the refrigerator section from around the dial area. Can fill up a small bowl in about 12 to 24 hours.
Most likely your defrost water drain is plugged. You will have to pull the panels off the freezer, to expose the evaporator. the defrost water drains by gravity thru a hole in the pan under the evaporator. Clear it of debris and or ice, check for any accumulated ice. reassemble. Remember to turn off power before attempting repair and be careful not to bend or puncture any refrigeration tubing
Jul 05, 2011 | Kenmore 64802 Top Freezer Refrigerator
Drip pan overflowing on Kenmore side by side refrigerator.
Sounds to me like your defrost heating element is shot. Unplug the refrigerator. Empty out the freezer take the screws off the back panel and remove panel. Defrost the cooling coils with a hair dryer. At the bottom behind the shield you will see a glass tube. Unplug it and bring it to your local app repair shop and let them match it up because making the phone call with your make and model doesnt always work but bring those numbers with you as well.There was some models made with single heating elements that had to work twice as hard to get the defrost job done so they burned out more often. Your repair store will probably have a new dual tube for ya. Hope this helps. Almost forgot..Make a temporary plug with a paper towel and stick it in the water drain just in case you drop a panel screw down the drain(not fun) good luck!
Jun 05, 2011 | Kenmore 53092 / 53094 Side by Side...
Kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
Aug 24, 2009 | Kenmore Refrigerators
Mine collects water under the crispers also.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 17, 2009 | Kenmore 64802 Top Freezer Refrigerator
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The refrigerator side is not cooling and the freezer side is working fine. Two weeks ago this same problem occured and I moved everything to my backup frig and allowed the kenmore to defrost over night....
it indicates the problem with defrost timer.actually the defrost timer sends the command to defrost the ice formed inside the tube after every particular time interval.if the timer is faulty.it wont defrost at all and the ice will keep clogging the tubes and so some sections of fridge wont get cooled due to clogged vents until its manually defrosted. to fix this problem you will have to get the defrost timer replaced.this will definately solve the issue.
thanks.
Jul 08, 2009 | Kenmore Refrigerators
Water leaking into the refrigerator from the freezer.
you have to defrost the freezer part and drain tube in the freezer,a hair dryer works well,if after you defrost it and freezes again its your defrost timer,make sure its fully defrosted first before buying the defrost timer
Jul 07, 2008 | Kenmore Refrigerators
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
229 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
