Question about HP LaserJet 3055 All-In-One Printer
Answering machine turns on and I can't receive faxes.
I have a HP Laserjet 3055 and it works great to send out faxes.
I have a Panasonic KX-TG5631 answering machine that answers the faxes.
If I disconnect the phone, it works perfectly, but i need them to be connected at all times..
  • OldJohn Dec 03, 2007
    Uniden integrated answering machine. HP3055 does not recognize fax call after call answered by machine. Worked with HP to no avail. Moved answering machine to another room.
  • bbayuk Dec 09, 2007
    answering machine opens and the fax opens also
I am not able to recieve fax is suggesting me that i have problem in fax tone but the phone connection is alryt
Posted on Jul 07, 2008
    Problem Solver:
  • 3 Answers
Why don't you consider a separate Phone/Fax switch. It will answer first ring and detect a fax and then ring the fax/printer you can set that to one ring as well, otherwise it ring the answering machine that is plugged into that and you can set that to answer on 3 or 4 rings. Then you have time to pickup phone if you are available.
Thanks what I do. The boxes are about $30 They are fairly cheap.
Posted on Mar 21, 2008
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Jul 08, 2009 | HP LaserJet 3055 All-In-One Printer
I can send a fax, but not receive one.
re-install your 3055. check for the manual on HP website. download it.
plus you may need a filter on your phone...fax boards are very sensitive to online static.
Jul 03, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 Lasrjet
receive set to manual set to automatic
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
Have two fax machines on two seperate broadband lines, both lines also serve internet/mail access which is working fine. Both faxes exhibit periodic/intermittent transmit and receive problems. Have had...
You can not send or receive faxes with any consistency on Broadband lines. You need an analog telephone line for these to work. Fax machines work on analog technology.
Jun 30, 2008 | HP Office Equipment & Supplies
My hp 3055 has not been receiving any faxes
The only thing that I can think of for you to do is to completly delete it from your computer & then re-download it. Only do this if you get no other resolution. Or you can call 1-800-474-7739 for hp technical support. I just did & they were a great help to me!
Jun 05, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
265 people viewed this question
Ben Johnson
