Question about Weber Grilling
Where can I buy an ignition switch for a Weber Q 300 BBQ?
    Top Expert:
  • Weber Master
  • 47,680 Answers
Any BBQ shop that sells weber
from weber manufacturer parts store
Posted on Feb 01, 2018
  • 38 Answers
SOURCE: weber 110LP gas bbq- igniter
This is either from the spring under the button being worn out or broken. or if the button and sleeve it depresses into is not clean. Try removing the button and checking to see if the spring is in working order. If the button is a contained unit and you do not have access to the spring, make sure that it is clean. If that doesn't work then you will need to replace the button. Check to see if you are still under warranty and maybe you can get a replacement free of charge or if the unit is new enough you may get a new unit altogether. I hope this gets you grillin again.
Posted on Sep 11, 2008
  • 63 Answers
SOURCE: Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Posted on Mar 16, 2009
  • 46 Answers
SOURCE: bbq regulator
should be able to get some help at your local hardware or home & garden store!
Posted on May 31, 2009
SOURCE: should there be fake coals in my gas weber bbq
Get rid of the fake coals they will only collect grease and cause a fire.
Posted on Aug 17, 2009
  • 3083 Answers
SOURCE: Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Posted on Jul 06, 2010
Weber q bbq
What is the model number? Here is a link to webers website http://www.weber.com this might make it a little faster for you to get your information.
Apr 28, 2013 | Grilling
Can i get a replacement switch for the ignition weber 200 switch will not ignite the gas there is no spark coming from the switch
First, you want to make sure the end of the piezoelectric switch is close to enough to something metal to spark. Maybe it got displaced when you cleaned the bbq?
If it is close enough to arc, but doesn't spark, you can replace the switch with this kit here:
http://www.grillparts.com/weber/Q200.asp?product_id=QSPARK
Good luck, and if this helped, please rate my response! Thanks!
Mar 22, 2011 | Weber Q200
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
Should there be fake coals in my gas weber bbq
Jun 29, 2009 | Weber Genesis Silver B Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Mar 15, 2009 | Weber Genesis Silver B Grill
Weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Oct 26, 2008 | Grilling
Grilling Logo
91 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
