Question about Whirlpool Duet GHW9150P Front Load Washer
I paused the washer to add more clothes when I tried to restart the washer it clicked and then turned completely off
  • 23 Answers
If you add clothes too late in the wash, this happens. The washers know when its to late to wash something effectivly, and they will shut off. sorry, but you will have to rewash what you were washing...
Posted on Jul 30, 2009
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH8700 - NP error code - Door locked and won't open
I don't know if you are aware of this, but Maytag did a recall on this washer in March 2007 where there was a risk of water leaking into the control panel and shorting out the board. You can follow this link to see if your washer was affected based on the serial number:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html.
Here is a link to your user manual to see if it offers any help. The only thing I saw was to use the Cycle Selector button to unlock the door.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/DC6802030B01.PDF
I found this on the Maytag site:
Is the door locked and the Add A Garment or Add Clothes light off?
If the Add A Garment or Add Clothes light is off, then the washer door will unlock after the Pause/Off or Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
You could also try their customer service number to see if they have a script for this problem: 1-800-688-9900
The only other solution I can offer is to disassemble your washer if its that urgent and you can't get a repairman out there.
Jan 10, 2009 | Maytag MAH8700AWM Neptune Front Load...
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Stuck in cycle
unplug the unit. wait 30 secs. and repluge, youll have to restart cycle. but should work DO NOT add more soap
Mar 18, 2008 | Kenmore Elite 45986 Front Load Washer
I need to reset the washer; after pausing to add clothes it is messed up.
Here is the manual if you need it; http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=WCVH6260FGG page 7 and 11 says that pressing start/pause again once the door is shut should restart the cycle. If you have had no luck with this then possibly there is a problem with the washer pump filter - GE claim this is not user servicable and i haven't been able to find exact instructions - usually this would be behind the panel at the bottom of the front (this should click off but check before you break anything) there should be a small (3-4 inch) screw plug which can be undone to check the filter. GE may be telling the truth though and it may be inside the machine and hard to get to. Unfortunately I think you may need to get a service man to look at it - it sounds like the controller may have died Phone GE on 1-800-626-2005 and ask - maybe others have had this problem Hope this helps
Mar 08, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
