Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron: Frozen Static Issue
I've got a 36" Sony Trinitron that's been consistantly flashing to static any time I try to use it. Sometimes just for a few seconds, sometimes for minutes at a time, but often enough that the picture is rarely visible. Occasionally, there will be two separate horizontal bars of static, but in any case it's always a frozen frame of static. I don't actually use this TV for the purpose of watching television (just console gaming through the front hookups) however this problem seems to occur regardless of where the picture is supposed to come from. The sound is unaffected.
  • 476 Answers
You could be experiencing two problems. the first part of your description states the static with two horizontal bars, this problem is usually erratic and it is caused by a defective varactor tuner(this happens while watching a channel thru your channel selector) the second part that it also happens while using the front hookups could be taht the front input connectors have developed some loose solder connections and thus the video problems (very common problem)
Posted on Jul 30, 2009
"no signal" on display, just static
Check the input selections, and make sure that the selection is right. Try connected to external antenna, select the input to TV, and make an auto-tune function, and see whether all the stations can be received or not. If not, the tuner of the TV has to be suspected.
Apr 26, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV has been getting static fuzzy lines, like snow in the picture increasingly bad. Now makes a pop noise, goes black for 2 seconds and comes back on. Thank you
Time ofr a new tv. The guns or gun control system is goign bad. Before it results in something worse ust replace the unit. Cost of repair is not worth the price.
Mar 02, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I did a reset on my Sony WEGA TV but now it's not connect with the cable box. Just says no signal. Screen is all snow and no sound other than static.
you need to reprogram channels. Itll only pick up 3 if you are still using coaxial cable from box, or change input to DVI/HDMI, aux, etc.
Oct 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Static noise and when put on max volume still not
sounds like blown speaker inside set. have you tried an external sound system?
Sep 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony FD Trinitron WEGA KV-36FS120 36" TV Problem
    The horizontal or vertical output transistors could be suspect in this case.
    Oct 17, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Black screen
    The blinking light is an error code. you need to count how many times it blinks, and check a service manual to see what the problem is, or ask a service person.
    Feb 21, 2008 | Sony FD Trinitron KD-36XS955 36" TV
    Sony FD Trinitron WEGA KV-36XBR800 36" TV
    I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
    Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
    Picture and sound go away after 2 minutes
    Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
    Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
    201 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
