RIM BlackBerry  Pearl  8100 Logo
Posted on Jul 30, 2009
Wont turn on
My battery went dead and now my phone wont Pearl wont turn on. The hour glass comes on for about ten seconds and then the screen goes black and continues do this for ever
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
605
Points
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jul 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
5212
Points
44
Www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
When i plug my blackberry pearl in its charger nothing happens. It wont turn on or nothing.
try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
1helpful
OK, my bb went to radio use turned off, when i plugged it in to charge, the screen went blank but stayed lit. I took the battery and SD card out along with the sim card replacing only the battery. when i...
go to www.blackberry.com and download the desktop manager for your phone and service provider and reinstall the software. if it is an unlocked phone you need to navigate to the common files/rim and delete the vender file first.
Ok so the screen on my pearl flip just goes blank or the white screen with the little hour glass comes up and itll go like that forever untill i turn it off, plug it in and turn it back on. is this a...
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working the software of your Handheld might got corrupted, in this you need to reinstal the software or walk into the service center.
Thank you for using Fixya.
White screen with the hour glass wont go away
try to remove your sim card and the memory card out of your unit and try to open it again
If that work then have it run for 5 minutes then turn off again put your sim card not your memory card, then turn it On again
inform us what happen
1helpful
Blackberry pearl wont switch on
It looks battery completly drained and dead (as It took so much time), the best way first to check "Circuit" status in Battery through Voltmeter (poles)..or another way go to any cell phone shop and give a trial with another batterty to check status of your unit.
3answers
I HAVE A BLACKBERRY PEARL , and hour glass pops up and freezes
I CAN NOT SOLVE THE PROBLEM AND I AM A ALLTEL CUSTOMER WITH THE SAME PHONE AND PROBLEM. THEY KEEP TELLING ME TO TAKE THE BATTERY OUT.
1helpful
Cell phone went dead and wont recharge
sometimes when battery becomes full discharged it takes time like hours to come up but over night charge will do it , if it dont check ur battery first if it is ok then ur set is dead there might be software issue seek help from support in ur country
1helpful
2answers
Blackberry pearl wont go past the white screen with the hour glas
the only thing that you can do with this issue is try wiping the software clean and reinstalling fresh software. You would need the blackberry desktop manager first installed on your home computer. If you dont have the cd the program is more then likely available on your mobile providers website. Once the program is downloaded and installed follow these directions
To perform this procedure, follow the steps below:
  1. Remove the battery from the BlackBerry device.
  2. Double-click Application Loader in BlackBerry Desktop Manager while the BlackBerry device is not connected to the computer.
  3. Click Next on the Welcome to the Application Loader Wizard screen.
  4. When the Communication Port Selection screen appears, connect the BlackBerry device.
  5. When the USB-PIN option appears, click Next. The Device Application Selection screen should appear.
  6. Re-insert the battery and allow the process to complete.
2answers
No power
take the battery out, wait 30 seconds, reinsert. it should start up on its own. if it doesnt work come back for more help.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
